Question about Olympus FE-280 Digital Camera
Lens in out
Lens travels in and out 4 times then camera stops
  • HDRI Dec 13, 2008
    My camera does the same thing lens in and out then goes off.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
It does appear to be a power issue and would need to go to repair. One way to check is to check the battery compartment or try another battery.
olympusamerica.com/repair
Posted on Dec 11, 2008
Canon 17-85 IS zoom ring locked at 17mm.
Sometimes, if that lens has heavy use or if it has been traveled with a lot, several of the internal zoom screws may come loose deep inside the lens and cause the zoom to freeze. It requires a complete disassembly of the lens to reach the screws and re-seal them so it does not happen again.
Bob Kilbourn www.camerarepairs.com
Aug 08, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
The camera has not been used for some time. First up it would not open at all. Then following clues in support response t4613896 fix 1,2 and 4 I got the lens out, grabbed it before it retracted and rotated...
Unless you're a professional photographer who depends on the equipment for your living, don't worry about it and continue clicking away. If the worst happens and your camera fails, your life will continue....maybe even with a new camera.
Jan 25, 2011 | Cameras
When looking through the lens - it is dark and all photos are dark even in well lit setting...
Is there a filter on the lens? remove the filter and try that. What mode are you shooting in? Switch to "P" for program and the camera will balance the light meter to a correct exposure. When looking through the camera viewfinder yes things will look darker then the scene because of all the glass and stuff the light is traveling through to get to your eye. Sort of like looking at something then putting a pair of sunglasses on. That part is normal. Also the faster the F stop the brighter the viewfinder will be. So lets say your 18-55 is an F4 lens. A lens that is an F2 will be a stop brighter and a lens that is F1.2 will be even brighter then that. You might not be paying attention to the light meter in the viewfinder which for correct exposure the needle needs to be in the middle between the - and + symbols.
Jan 11, 2011 | Canon EOS-20D Digital Camera
Lens mechanism not travelling fully
Use your vacuum cleaner to pull the dust lodged between the lens casing and the camera body. Do not blow it in.
Aug 21, 2009 | Cameras
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
My Tamron 1.4X tele-converter stopped autofocing.
Tele convertors on their own do not focus - that is achieved by the lens. Are the lens contacts clean and correctly aligned with those in the camera ?
May 15, 2017 | Tamron Cameras
Nikon D50 While shooting pictures the shutter button stopped work
TURN ON CAMERA. SEE IF THERE IS A MESSAGE. NOW, TURN OFF CAMERA. TAKE OFF LENS. REPLACE LENS- MAKE SURE YOU HEAR A "CLICK" TURN ON CAMERA AND TRY AGAIN. OK?
Mar 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Virtual tour
the picture is blurry due to lack of focus in the lens.
Im using a fish eye lens. my f\stop is 6.3 shutter is 30.
Im trying to due a virtual tour of my kitchen so its a big picture that i want all in focus. i have tried different settings on my camera but i think im making it worse.
Feb 07, 2008 | Nikon D70s Body Only Digital Camera
Zoom lens
What camera are you using is the lens making a noise when it stops focusing  call sigma imaging uk 01707 329999
Oct 19, 2007 | Sigma AF 28-200 Lens
My Optio won't stay powered on.
This is probably due to a broken sensor tab inside the lens, or a failed sensor. When the lens reaches the end of its travel a small plastic tab will pass between the ends of a C shaped sensor and let the camera know the lens has reached the end of its travel. You are not hearing a safety device, you are hearing the gears actually slipping. Don't let it do that too much or you will turn one problem into two problems quite quickly. If you cant find the broken part it will require professional repair. I would advise against taking the lens assembly apart. They are extremely hard to get back together and you very well may end up with a junk camera. David Millier Advance Camera Repair
Feb 11, 2007 | Pentax Optio 430RS Digital Camera
Olympus FE-280 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
