Hdmi channel not showing PS3 only sound
The HDMI was working but now only sound from the PS3 comes through this channel.
I have a SONY KDF-E50A12U 50' rear projection tv.
Can you shed any light on this matter?
I've also heard that there is an hidden menu within the remote to ajust light on the tv?
Thanks Paul
    Problem Solver:
  • 5 Answers
Might be problem with PS3 rather than telly. Try another HDMI cable in case something wrong with yours. You can try and reset PS3 video output by holding power button down (when in standby mode) until it beeps, them use original cable and see if that shows up on your TV. If so reconnect HDMI cable Ps3 will detect it and change settings back to HDMI then see if the TV picks it up.
Posted on Sep 11, 2009
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Jan 05, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
Ghosting on hdmi channel on my sony bravia
With HDMI there should be no ghosting. And being a Sony Bravia it should be no ghosting. My 52" Sony is great.
You've got connection issues.
Nov 25, 2009 | Sony Televison & Video
Ps3 sony grand wega (4 yrs old)
Press the input button on the tv itself to select the proper input you desire.
Dec 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Double vision on tv
http://www.avforums.com/forums/showthread.php?t=384717&page=8
this will fix it i have the same tv and it fixed my i have a prob my tv has gone dark and can not c the pic i had to put the brightness up just to c it
Dec 27, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
50" Bravia KDF-E50A12U
read about this last night see http://www.avforums.com/forums/showthread.php?t=384717&page=9
seems there is an easy fix
Nov 12, 2007 | Sony KDS-R50XBR1 50" HDTV
Televison & Video Logo
345 people viewed this question
Top Televison & Video Experts
Electro Med Services...
