Question about ASUS MyPal A626
Asus A626 WiFi
For some reason my A626 will not connect to any of my 3 DLink wireless routers. It can see them, but won't connect. I have no problem connecting to my NetGear wireless router though.
I fixed my problem with my D-Link DIR-625 router by going and changing a couple of things. I'm not sure which one did it, but this is what I changed:
1. Under the advanced tab turn off 'Wi-Fi Protected Setup'
2. Under the advanced tab - Advanced Wireless option:
Advanced Wireless Settings Transmit Power : High Medium Low
Beacon Period : (20..1000)
RTS Threshold : (0..2347)
Fragmentation Threshold : (256..2346)
DTIM Interval : (1..255)
802.11d Enable :
WLAN Partition :
WMM Enable :
Aggregation Limit : 8 Kbytes 16 Kbytes 32 Kbytes 64 Kbytes
TPC Max Gain : (0..50)
Aggregation Max Size : (2000..65535)
Aggregation Num Packets : (1..64)
Force Short Slot for 11N Clients :
Short GI :
Posted on Dec 29, 2008
  • Randall Spychalla
    Randall Spychalla Dec 29, 2008
    Sorry, the settings for #2 cleared out during the submit.
    Set Beacon Period to 400
    Turn Short GI off
    Everything else should be at the default.
Asus mypal a626 will not stay connected to cisco
hello,
ok take a look for connection and securite setting in asus.
Sep 10, 2009 | ASUS MyPal A626 Pocket PC
I am trying to connect my asus mypal to my wireless internet
Hi, I helped a friend of mine with his wifi setup. His WEP Key was on the side of his router. I don't remember the exact work but it was something Key. It was 10 numbers long just right for a 64 bit key. If you are using Win XP there is a wifi setup in there. I have a mypal A626 and had it up and running in a few minutes on my wifi system. If you have security, you will need to find the code in order to get a connection. grader01
Apr 12, 2009 | ASUS MyPal A626
Why cant i connect my dlink
Forget the D-Link drivers!!! I suffered with this same DWL-G630 issue for two years, trying different settings, reloading drivers, all with no solution. My card kept dropping it's connection, or wouldn't connect at all until I removed then replaced the card. Finally, I read on another forum this card uses the same chipset as an ASUS card, and to try the ASUS drivers. I downloaded and manually installed the drivers from here:
ftp://ftp.asus.com.tw/pub/ASUS/lan/wifi-g/wifi-g.zip
Unzip it, but DON'T run the setup.exe file, because it will try to install the ASUS program. If you open the unzipped folder you will find another folder called "Drivers". Just use your Network Settings (from your Control Panels) to manually update the driver of your DLink card, and navigate to the Drivers folder just mentioned. Reboot -- you'll probably have to reconnect to your access point/router one last time, but that's it! It's good as gold after that.
I was used to losing connections 5-8 times PER DAY (I'm 15 feet from the router!) and now I've been connected non-stop for two weeks and counting!!
Mar 20, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
WIFI & WBR 1310
Fix your router again. If the wifi is fine, you just have to let the nintendo search for the wireless network and connect to it. You don't have to do anything on the router to let your nintendo to connect.
Feb 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How to change (or update) wap to wpa encryption on ASUS WIFI-B Network Adapter
With this Asus wireless B adapter even the new driver dont support WPA wireless security , because right now sicne WPA is a much newer and higher type of wireless encryption only some wireless B adapter supports that and sorry to say this wireless adapter that you have don't support it even with the latest driver so it will be better to get a new wireless G adapter that supports WPA 100% , you can get the wireless adapter from Asus or from other wireless device manufacturer like Linksys, Netgear. Dlink and Belkin....
Nov 02, 2008 | ASUS WIFI-B Network Adapter
WIFI SD CARD
Test the network capability - ping your card and also do an auto detect through home network set up.
If it still doesnt feature, unplug, reboot phone and replug. shoul;d work!
Mar 11, 2008 | ASUS MyPal A626
ASUS A626 Wireless 802.11b/g
It doesnt go thru walls very well, 5m seems the limit with deteriorating signal. Rather get your wireless router out into the open (not hiddden behind a computer desk) and the antenna pointing in the direction of the other one. There is a signal strenght utility that asus has that stays resident as an app. use that to assertain your signal viability
Dec 29, 2007 | ASUS MyPal A626
How to Configure D-link dwl-510 WiFi Card
To configure your linksys, access point, we need more information, the ipaddress oif your dlink router and the wireless settings on your dlink router..,
for more informations, check this link http:kb.linksys.com
for more details contact linksys; 18005465797
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
ASUS MyPal A626 Logo
538 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
