Question about JVC XL-SV22 CD Player
No video displayed on tv screen.
There is only 1 video out (RCA jack). I can't get a signal to the tv through it while the disc is playing.
Thank you for helping
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Normally, video uses the color yellow, Please ensure that the yellow RCA Video OUT of the DVD goes to the yellow RCA Video IN of the TV.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    I have a LG47" tv
    Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
    You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
    Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
    I hope this helps and good luck! Please rate my reply. Thank you.
    Mar 25, 2011 | Audio Players & Recorders
    On screen display menu
    Almost always, there would be a yellow RCA female jack at the rear of the receiver that is marked "VIDEO OUT". With an RCA to RCA cable, connect this VIDEO OUT to a composite "VIDEO IN" of the TV. The TV must then be set to display AUX / LINE / VIDEO 1 / AV.
    Good luck and thank you for using FixYa.
    May 28, 2009 | Denon AVR-4800 Receiver
    How to hook up vcr and dvd together ?
    |DVD| -> |VCR| -> |TV|
    1. Connect your VCR to your TV. (Using Antena cable or RCA cables.)
    2. From your DVD player, choose the AUDIO VIDEO OUT. Then, connect that to your VCR's LINE IN jacks.
    (*)Your DVD player has 3 jacks coming out. Yellow-video, White- Audio Left and Red- Audio Right.
    If you VCR does not have the RED jack. Go to a radio shack and tell on of the sales person taht you need to connect 2 RCA audio outs to 1 RCA audio in. (He/ She will give you a "2RCA Male to 1RCA Female" splitter)
    3. Finally, play your DVD, put your VCR channel in TV and most important select the LINE channel in your VCR. (This channal may called as L1, Line,... etc)
    You should be seeing the DVD in your TV now.
    If you want to play the VCR, just put the casset and play.
    Important- The VCR needs to be powered on in order to the DVD signals to go to the TV.
    Cheers!!!!
    Feb 27, 2009 | TruTech TT1620 DVD Recorder
    Copying dvd to vhs
    1. Locate the output jacks DVD player. Sometimes they are standard female RCA A/V jacks, like those found on the front of many VCRs. Others are more tricky, having a small jack that looks like a stereo headphones plug. These camcorders require a special cord that converts a 1/8" stereo signal into RCA A/V male plugs.
    2. Using the proper cord, connect your PLAYER to the VCR's RCA A/V input jacks, usually found on the front or back of your VCR.
    3. Turn on your VCR and TV, so you can see the input from the camcorder. You might have to select "Input 1/2", "Line 1/2", or "VIDEO" depending on your VCR model. You should now see whatever is on your camcorder displayed on your television.
    4. Press "Record" on your VCR, then press "Play" on your camcorder. That's it!
    Aug 09, 2008 | Televison & Video
    Hitachi ultravision 50v500
    there should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
    usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
    Apr 14, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
    Snowy screen playing dvd's
    1.Check audio/video RCA jack cables
    2.check S-video(if you use S-video cables)
    3.check with another dvd player to get normal picture on your tv system. if picture is normal in this process. then problem with your old dvd player.
    4.if same problem occurs in other dvd player. then problem with your television. external audio/video processing circuits
    5.if the tv is ok. then the problem with your old Dvd player audio.video converting circuits
    6. if can be rectified by authorised service engineers
    7.Contact service engineer. as there is no recitification process from user part
    Dec 15, 2007 | Hitachi 43FDX01B TV
    Video output not working
    it sound to me like you have a broken connection on yourvideo out jack on the main unit becouse you say the lead is fine and the tv screens work with another unit.this can be caused by the plug being pulled out in a wrong angle. ask an audio dealer to chech the solder connections in the unit to see if they are making a connection with the pcb(printed circuit board. hope this helps
    Feb 25, 2007 | Kenwood DDX-6019 Car DVD Player
    JVC XL-SV22 CD Player Logo
    119 people viewed this question
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
