Question about Bionaire BAP1300 Air Purifier
Hi. the plug of our bap1300-u was pulled from the wall.
When we plugged it back in and a faint screen showing every possible "failure" or "issue" and setting appeared. Also, the red light furthest to the left above the screen is illuminated.
Any possible reset?
Thank you for your time.
Philip
2 Suggested Answers
maklean
  • 1665 Answers
SOURCE: Bionaire BAP1300 -- Working fine for 2 Days then, Red Light
It may be its power supply fault
Posted on Jun 09, 2008
It will not turn on it says it locked how do i get this off of the screen and get it to turn on quiet flow is the nameof it
Crystal, first turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging the unit back in. After you plug it in, turn the Master ON/OFF Switch to ON and set the controls as you wish. Hopefully, during that 12 - 15 minute timeout, the unit reset itself and should now work normally.
If that doesn't solve the problem, you can call Hunter Technical Support. In the US dial 888-830-1326.
In Canada dial 866-268-1936
Apr 15, 2011 | Hunter Air Purifiers
Try to do a hard reset by unplugging the device from the power outlet and wait for sometime to reconnect.
Jun 09, 2008 | Bionaire BAP1300 Air Purifier
Will not turn on - no power at all
If your Breeze was working, but you cleaned it and now it won't turn on, the problem almost certainly is with the reassembly of the components. Go through the following checklist.
1) Make sure the plug in the back is inserted firmly and the wall socket is live.
2) The little switch by the plug should have the "I" end depressed and the "0" end up.
3) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly).
4) Make sure the plates are inserted correctly, with the top and bottom in the little grooves and the metal fingers pressing firmly on the screen part of the plate. You may need to twist the white upright posts slightly to align the contacts.
5) Try both the manual and remote controls. If the manual controls work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote. If one set of controls works, but the other doesn't, you may operate the machine with only the working controls and ignore the others.
6) If none of the above suggestions helps, remove the plug in back, and pull out the fuse to see if it is blown. Very infrequently, a sudden powerup or power surge will blow the fuse. If so, replace it with the EXACT same size fuse, available at an auto parts store.
If none of these troubleshooting steps works, then it would appear that the problem is in the computerization. Unfortunately, Vollara (new name for EcoQuest) is no longer servicing nor selling the Breeze. Your only option to get it fixed would be to find a dealer who still has some, along with extra parts, in stock. If you call Customer Service, they will give you some trade-up options. 800-989-2299. Use #16618 if you need a referral number.
Feb 12, 2011 | Ecoquest Breeze AT Living Air Purifier
My unit will not come on
You probably have a loose connection or component somewhere in the machine, or possibly the motherboard/computer system is non-functioning.
First, check all connections and components!
4) Try both the manual and remote controls. If the manual control work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote.
5) Remove the plug in back, and pull out the fuse to see if it is blown. If so, replace it with the EXACT same size fuse, available at an auto parts store.
Jan 25, 2011 | Ecoquest Breeze AT Living Air Purifier
Our Air Purifier stopped functioning and no longer turns on. We tried with different electrical plugs and that does not work either. Basilio Rodriguez 1001 E. Clark St. Warsaw, IN...
1) Make sure the plug in the back is inserted firmly.
4) Try both the manual and remote controls. If the manual controls work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote.
Jan 15, 2011 | Ecoquest Breeze AT Living Air Purifier
I have a Breeze AT that has not worked since the last time I cleaned it. It was working fine before that and I put the plate and filter back in the same way (as far as I can tell). Can you help me? I...
One of these first three options is most likely the problem, since the machine was working before.
If the machine still won't work...
4) Remove the plug in back, and pull out the fuse to see if it is blown. If so, replace it with the EXACT same size fuse, available at an auto parts store.
Jan 14, 2011 | Ecoquest Breeze AT Living Air Purifier
Why does my Breeze randomly change fan speeds and purification levels?
The most common reason for surging or changing power levels is a loose connection somewhere.
1) Make sure the plug in the back is inserted firmly and the wall socket is live. The wall socket should not be powering a high-use appliance such as a furnace or refrigerator.
2) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly).
3) Make sure the plate is inserted firmly and correctly in the top and bottom "tracks" inside the machine. The metal contact fingers should be pressing firmly and evenly on both sides of the plate, in the metal screen area. You can bend them a little to increase the pressure. You may need to adjust the upright white ceramic posts to align the contact points. (Sometimes they twist.) Make sure the screws that hold the contact points are in firmly.
If none of these troubleshooting suggestions solves the problem, it may be malfunctioning because of computer issues. Unfortunately, Vollara (new name for EcoQuest) no longer services nor sells the Breeze model. However, customer service will inform you of your options. 800-989-2299.
You may also attempt to locate dealers who still have the Breeze in stock, and/or parts. You would need to do this by first asking Customer Service to locate a dealer in your area. They'll give the dealer your number, hopefully the dealer will call, and you can ask them to inquire among their associates.
Jan 13, 2011 | Ecoquest Breeze AT Living Air Purifier
My fan won't work. It has not been used much at all
First, unplug the unit from the wall. There is high voltage inside the unit, so use caution.
Next, check the fuse on the back of the unit. If it is good, then you need to check the fan.
Corrosion can build up on the interior of the fan assembly. Remove the filter and look for the connections at the bottom of the fan motor. Make sure they are not loose, corroded, or disconnected. If you have a meter you can use to check the voltage, or know someone who can, see if voltage is being applied to the fan. You will need to plug the unit back in, so remember the high voltage on the screen, and on the needle emitter at the front of the unit. If voltage is present, you can go to the Alpine web site and order a replacement motor. This is a common failure item. If there is no voltage, the unit will need repair.
Aug 31, 2010 | Ecoquest Flair Air Purifier
Not returning to 100%
Reset filter reminder:
Unplug power code.
Push and hold sleep button.
Plug power code while pushing sleep button.
LCD shows "P" than release the button.
Push sleep button and you can see 99% filter reminder.
Jul 09, 2008 | Bionaire BAP1300 Air Purifier
Bionaire BAP1300 Air Purifier Logo
29 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
