HP PSC 1315 All-In-One InkJet Printer
Problem for HP PSC 1315 All-In-One InkJet Printer
HP 1315
By rhumb on Mar 05, 2007
When the priner is powered up the print head slams violently to the right and left 3 times then stops on the right hand edge. Check print cartridge flashes amber an "E" on the display and the black and color cartridge lights are on.
Same Problem
Aug 03, 2008
-   Yes, I have the same problem on power up with the print cartridge slamming right and left, shaking the whole printer. I've taken it apart and don't see any problems with detached striped ribbon, don't know what the clear encoder strip is that's referred to -- that needs cleaning. I've looked at it close and there is no thin clear strip. Just the white ribbon with stripes under the print head, that is perfectly fine. I notice it seems to be trying to do something on the right side, where the cleaning area is, that's where it's confused. There was a big pile of gooey black ink in the docking bay? which I took out. There is a clip that fell out, stainless steel, flat, with two hooks on the top of it, very small piece. Can sort of see where it goes, but putting that in place made no difference. Also a stainless steel rod was loose, about 1/4" long, don't see where that goes. My intuition tells me it's part of a sensor as there is one like it on the left, where the print head rises up. Perhaps I just need more details on what is this encoder strip, what does it look like, any photos of this printer to show it? Thanks -- Beetsy-   ysteban
May 10, 2008
-   I have this problem with my ij1200 printer. The cartridges slam to left and stay there. Also green power light keeps flashing and i can not turn printer off by the power button! it won't go off-   nesha1217
Best Solution
posted on Jun 11, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
this is caused by a dirty locator strip these are located as a clear ( nearly clear strip) passing thru the print head. wipe it off with 409 on a soft cloth. careful do not dislodge it it is delecate
Solution #2
posted on May 06, 2007
Very Helpful)
bbazz
Rank: Guide
Rating: 88%, 12 votes
the usual cause for a carrier slaming to one side is the timing belt is either out of place or is dirty. The timing belt is a narrow strip running from one side of the printer to the other side. This strip runs through a sensor on the carrier. open the lid to find the strip clean with isoproply alchohol check to make sure it is not twisted or out of place.
Was this helpful?
Yes
No
Solution #3
posted on Mar 08, 2007
Somewhat Helpful)
douce
Rank: Apprentice
Rating: 80%, 4 votes
This all new to me so please tell me what I should do to correct this problem? I really am new to this sort of thing. Thanks Douce
Comments:
Mar 08, 2007
- Please does this mean that I would probably have
to put in a new print head assenbly?
How do I check the circuity and what is it?
Douce
Was this helpful?
Yes
No
Solution #4
posted on Mar 06, 2007
Somewhat Helpful)
leslicom
Rank: Apprentice
Rating: 76%, 12 votes
Sounds like you have a problem with the ribbon cable or the circuitry on the print head assmbly. The ribbon is usually a suspect if the cartridge lights are on. If that doesn't solve the problem check the circuitry.
Was this helpful?
Yes
No
Solution #5
posted on Jun 09, 2007
Somewhat Helpful)
diespy
Rank: Wiz
Rating: 81%, 112 votes
Normally what I've found that happens is this:
a clear thin tape like ribbon has detached from the printhead carriage. Check for that. If it has simply detached, all you have to do is re hook it to the side it detached from. If it is broken, it would be less hassle for you to just go buy new
Was this helpful?
Yes
No
Solution #6
posted on Jun 19, 2009
Not Rated)
epdc
Rank: Apprentice
Rating: 0%, 0 votes
hi i got a cartridge problem
Was this helpful?
Yes
No
Solution #7
posted on Aug 03, 2008
Not Rated)
ysteban
Rank: Apprentice
Rating: 0%, 0 votes
Using the same terminology would be helpful:
ribbon cable
encoder strip
locator strip
clear thin tape-like ribbon
timing belt - narrow strip
are these all the same thing?
Betsy
Was this helpful?
Yes
No
Solution #8
posted on Sep 20, 2007
Not Rated)
punker0204
Rank: Wiz
Rating: 84%, 102 votes
check the encoder strip if its on the right groove of the encoder strip sensor. and try also to replace the encoder strip sensor damaged sensor results with this kind of violent error.
Was this helpful?
Yes
No
Popular Solutions for HP PSC 1315 All-In-One InkJet
Questions and Unsolved Problems for HP PSC 1315 All-In-One InkJet
Do you recommend HP PSC 1315 All-In-One InkJet Printer?
Answer
Answer
I need help with my printer,how it operates and everything.
Answer
When printing a 4x6 photo the last quarter to half inch comes out all white. Is there a fix for... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
