Question about LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive
Will reinstalling Netowrk Drive (E.B.Disk) delete everything on
We have just moved offices so we had to disconnect hard drives and what not and reconnect in the new office. Unfortuantely, I can not view our LaCie Ethernet Big Disk on my computer (Windows XP). There is a large yellow uestion mark on the device in the device manager panal. It is telling me it was installed incorrectly, but I was able to view it in our old office perfectly fine. Although, there was a large yellow explanation point on the device in the device manager panal when we were at our old office.
I have an option to reinstall, but I don't know if that would erase everything on the hard drive. Will it?? Any info on this would be great!
Thnaks all.
Jen
  • jen210 Dec 11, 2008
    OK...I thought it might delete the files. Thanks for the confirmation.
    So this is how it is hooked up. It is connected directly to my computer via USB, but it is also connected to our network. My studio manager who is in the same room and uses the same network, can see it fine. My second computer could see it at one point, but now it does not see it.
    Should I just shut it down and unplug the hard drive from my computer (USB) and see if it just shows up on my computer via network??
    What will finding the ip address for the hard drive do?? Thanks.
    Jen
    Hey again,
    I have disconnected the USB cord from my computer and the hard drive so it is only connected to the network hub. I shut the hard drive down first as well as my computer and then rebooted them both. My computer is not recognizing the drive. I haven't found the ip address yet.
    Also, I didn't understand how you suggested to look for the ip address of the hard drive. Can you give a little more info? Thanks.
    Jen
    Problem Solver:
  • 18 Answers
Wait.. If you have this hard drive it should be connected using network adapter right? you make it sound like it is connected through USB. Reinstalling the driver on your pc is not a bad idea and it will remove the hard drive files. I suggest go to another pc and search from there. Also, find out the network ip address of that hard drive. If it is plugged in to the network switch then it would be easy for you to access the files even without installing the drivers.
accessing the drives and shared folder:
start-> run and type in \\harddriveIP\sharedfolder
if you don't know the ip use the software lookatlan to search for it.
Posted on Dec 11, 2008
  • Mark Dec 11, 2008
    Yes the shutting down of hard drive and unplugging the power and plugging everything will do a warm boot and will probably fix your problem. What you can also do is unplug your usb hard drive from your pc and plug it in on a different usb port. That should probably look for the driver and fixes your problem. Be sure
    you have at least power users right or administrator right on the pc. I never heard that a hard drive can function even with hard drive and usb is being used at the same time. Anyways, the purpose of IP address is for you to be able to manage and access it anywhere within the network. Lets say your boss just buy a new computer and replace the old one, and he/she wants to access the hard drive from her new computer. You can just go to start and the run and type in the "\\" and then ip address of the hard drive and biam! she can access all the files on the hard drive. Google accessing network hard drive to pc.
  • Mark Dec 12, 2008
    Forget the ip addressing for now. If the pc still can't see the hard drive, try to plug it in on another usb port and restart the pc and the hard drive. See if that could fix it. Also, monitor your boss is still connected.
Help how to format lenovo ideapad s300 in windows 7
If you want to format your entire hard drive (and reinstall windows) You'll need to insert the appropriate windows disk. If you want to reinstall 7, insert your windows 7 disk and boot off of the disk (When booting, it should start by showing a screen that says "Press any key to boot from CD..." and you can just press a key on your keyboard. From there, follow the on screen instuctions. When you get to the drive partitioning step, select your hard drive and partition you want to format. You can delete the partition you have and make a new one if you want to totally clean the computer (WARNING: This will literally delete everything on your computer. Everything). From there you continue and finish the setup (it may run for a while). And you have a fesh new hard drive and operating system install.
Sep 12, 2013 | Lenovo IdeaPad S300 Laptop Computer -...
On start up, netbook gives "Disk Read Error. Press
1. See If there is something attached to the computer (printer, usbo devices, phones etc.) . If there is disconnect it
1. Try checking the BIOS make sure the first boot device is the hard drive save the changes and restart the computer
2. If that fails. Try restoring the BIOS to its factory defaults
4. If you can't still boot up. try do a Operating System Reinstall
5. If everything else fails Replace the Hard drive
Thank you for Choosing
Jul 03, 2011 | HP Mini 1000 Netbook
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Help transferring files from computer hard drive to La Cie
Well you can ONLY transfer/Move DATA as Programs and Documents & Settings and User Directories, cannot be shifted at all. So It is only the Files and Data that can be Moved off a drive. To gain space back, Right Click on the HDD, go to properties, in properties Under the general, tab the first window, select disk cleanup, remove everything in those boxes and after, that look under Tools tab, & do a disk defragment. This may get you space back. If not you may have to get a new bigger drive, and clone your old drive, then install the new drive and reinstall the Cloned image back onto the new drive?
Mar 30, 2010 | Computers & Internet
I need to make room on my internal ''C'' drive...was advised to move as many folders as poss to free up space. Have moved Pix, Movies, Doc, Links etc to my WD 500 gb ext HD, but cannot move desktop or...
Have you "emptied" your Recycle Bin?
From the "Start" menu, look in "Accessories".
One of the accessories is a "disk cleanup tool". Run it.
It will also delete all your "Temporary Internet Files" that Internet Explorer has created.
Now that you have "moved" your pictures and movies,
what will you do if your external hard-drive "dies",
taking your _only_ copy of those files to its grave?
It's time to buy a *NEW* "internal" disk-drive, e.g., 400GB for under $100 for a "laptop" disk-drive, reinstall Windows onto it, and copy (not "move") all your files from the external disk-drive to the new disk-drive.
Jan 04, 2010 | HP Computers & Internet
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
Unable to fix or remove microsoft office 2003
If you cloned the hard drive, everything should work. In windows, that's what you need to do if you don't have a utility to actually move your programs to a new hard drive.
The answer to your problem is: Reinstall the program from the program CD.
Jul 15, 2009 | Microsoft Office 2003 Professional Edition...
MY C drive Booting drive is 30GB, in side c drive file properties is showing 20GB bt free space is showing 2GB
Its probably formatted not to use the entire space of the disk, is there another partition or "D" drive where your restore/backup stuff is? That could be take up the rest of the space. Hard disks are always described as being a certain size but can be formatted by windows tlo split up the drive into smaller chunks called partitions. Your C drive/partition might be way less then 30Gb therefore only showing up as 22Gb
May 17, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
2 drives
You really only have one drive. The d drive is a partition of your c drive. It is used for backing up your operating system and system restore.If you need more space, delete your programs that you dont use often or burn them on a disk. Do this with pictures also. After you delete everything you dont use run your defrag. Just be careful you do not delete any windows files
Jan 18, 2009 | Computers & Internet
Very low on hard disk space!
YOU NEED TO BUY A LARGER HARD DRIVE.YOU CAN GET A 250GB.DRIVE FOR AROUND $100USD OR LESS.ONCE INSTALLED MOVE/TRANSFER FILES TO NEW DRIVE.
Nov 30, 2008 | Computers & Internet
LaCie Big Disk Extreme (300797U) 1000 GB Hard Drive Logo
217 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
