Question about HP Q2613A OEM Genuine Black Laser Toner Cartridge for HP LaserJet 1300 Series Printers
Repeating wide smudgy horizintal line across my printed pages
I have a repeating wide smudgy horizintal line across my printed pages, 7 stripes to a page.
I've tried making 30 or so copies hoping it would fade from use, correcting itself, but there was no improvement at all.
Teh stripe is thicker in the middle, and tapered at the ends. It looks something like this:
  • sylviadelaro Jan 20, 2009
    i have the same problems. exactly 7 lines across the page, like one inch apart from each.
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Posted on Feb 16, 2009
Black lines across the page
hi there,
unplug cartridges and check its heads are clear if not take a tissue paper and cleane it very gantelly, intall the cartridges and run cleanning test from printer properties.
Jul 11, 2010 | Lexmark X2600 InkJet Printer
When we print our labels using this printer, the colours on the left are all faded out & pale for about the first inch & half, all the way down the page - particularly on yellows and pinks. Back to...
Yes:
1) First, clean the elctrical contact wires in the cartridge bays with alcohol on a Q-tip.
2) Make sure all cartridges are seating completely.
3) Open the front door. Check the wide, black transfer belt (ETB). See if there are uneven wear signs, lines on the belt-side where the colors are faded on the page. If it looks hazey, you can use 95%+ isopropyl and a lint-free cloth to clean the residue off.
4) Remove the ETB and reseat it (may not be easy on this model).
5) Make sure you've tried original hp cartridges -- not only compatibles or refills.
6) If all the above fails, you will need a new ETB. If so, look online by model number "CLJ 1600, ETB".
You may find a refurished on a lot cheaper than new. However, this is a user-consumable component and must be replaced when they wear out.
May 11, 2010 | HP LaserJet 1600 Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
First print line print fades away across page,
The page size is off. Try readjusting it in your "printing preferences". Otherwise, if it is new, back to the store for a replacement. It really should not do that.
Sep 02, 2009 | Lexmark 2391 Plus Matrix Printer
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Mar 25, 2008 | Xerox Phaser 8550DX Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
HP Q2613A OEM Genuine Black Laser Toner Cartridge for HP LaserJet 1300 Series Printers Logo
343 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
