Brand new heater: flame fires out (flickering) on end while running Pressure is set right
  • kimber_ga02 Dec 11, 2008
    heater will not stay lit???
  • Heating & Co... Master
  • 3,182 Answers
Natraul gas or propane ?
Posted on Dec 11, 2008
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
Dec 23, 2015 | Dimplex Heating & Cooling
Pilot flame seems too high. How can I adjust and how tall should flame be?
The pilot flame should be a firm blue color impinging directly on the thermocouple enough to turn it red hot after a few minutes. Generally, the pilot flame need not go past the thermocouple more than a 1/4 - 3/8" and should not be a lazy yellow color. As far as adjustment to the pilot flame, it depends on the heater brand you have. Look at the gas control for a small adjustment screw near where the silver pilot tubing connects from it (it connects to the pilot assembly on the other end). Adjusting it counter-clockwise will lower the flame size, if necessary. If the pilot has a lazy yellow flame, the pilot orifice may just be dirty. With the pilot flame off, use a can of compressed air (with attached straw) to blow out any debris/dust from inside the pilot assemble where the orifice is. Good luck.
Mar 18, 2015 | Heating & Cooling
Hot water heater flame problem
What size is the orifice? Are you using LPG or CNG? What pressure is the regulator set to?
Jul 14, 2013 | RTO Atwood Water Heater - 6 Gal LP
Rheem RTG-64DVN model, brand new unit installed during the weekend. fired up but shout down automatically within about 5 seconds. showed error code 12.
contact your gas company if the error code is "12," indicating that the gas supply was interrupted.
have a good day !! In LP models, the 12 error code may also appear if the LP gas supply has gotten low. To clear the code, replace or refill the LP gas supply.
go here for a list of codes for rheem tankless water heaters--
May 09, 2011 | Rheem Tankless Hot Water Heater...
Will not fire with cover attached
Bend brackit on photo eye so that it gets a better view of the flame. When cover is on the flame will move farther to the end of the heater. You can test this by holding the eye in your hand and pointing it at the flame. I had the same problem. Hope this helps.
Jan 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fan on, sparks 3 times, won't run
Shut off the gas to the heater and pull the ignitor out. Turn everything on and push the button in the door opening to get the heater to turn on. Look at the ignitor and see if there is spark across the probes when you hear the clicking. If not, replace the ignitor.
If there is, put the ignitor back in the heater and then look at the valve. The two wires that bring the 115V to the valve need to be pulled and then checked with a meter. Start up the heater again and look for the 115VAC when the ignitor starts sparking. If you see it, replace the valve. If not, replace the control board.
Jul 05, 2009 | Hayward H Series Induced Draft Abg 100,000...
Can not adjust air pressure to keep it running!!
Provided the rotor and vanes are serviceable the pump should produce around 10 psi if you completely close off the airline tubing. If your gauge will not read with the tubing totally restricted, then I would check the relief valve to see if the ball is in first, then the spring, then the screw with the hole. These items should be in the longer of the 2 bosses. If no pressure reading at this time you either have a broken rotor or a defective gauge.
If you get some pressure with the tubing restricted, but there is not enough, then use soapy water to find the air leak. If there is a crack in the plastic end cover- replace it.
How to set the pump pressure
Dec 11, 2008 | Reddy R155D Utility Heater
Three bar fire keeps going out
Look at the burners and see if there are any cracks or irregularities. Also the flames should be nice and blue in color, if not, then some new burners may be in your future.
Jan 07, 2008 | Heating & Cooling
Pilot light seems to high
there may be an adjustment screw for pilot height. you'll have to look at the valve. a pilot should have an inner cone of greenish blue color and the surrounding flame should be a deep blue no yellow or orange tips. the pilot burns pure fuel no air. the main valve does mix air with the gas in order to burn.
Oct 24, 2007 | Procom ML300EBC Heater
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
