Question about Husqvarna Viking 1
Brother NV1000 (Innov-is 1000) sewing machine jammed
Yesterday, I was embroidering when the machine just stopped to worked, started to make noisy beeps and this message appeared : The safety device has been activated. I did everything that they say in the user manual to remedy the problem, but nothing worked. I can't even turn the handwheel by hand. The machine is clean, as far as I can see, but I can't even open the covers to see inside, so I don't know if there is something blocked inside the mechanical parts, or if the mechanical is the problem. Is there a way to open those plastic covers to look inside ? Thank you very much !!!
SOURCE: Needle Sticks - Huskystar E10
same here
Needle was not inserted all the way up (very sensitive)
Posted on Sep 07, 2008
SOURCE: Designer 1: upper thread shredding while embroidering
I too, have the same problem withmy Designer 1. I just bought ISACORD brand polyester embroidery thread to hopefully solve this problem, but I believe it must be a tension problem. I have a "date" with the repair lady on Friday (11/22/08) and if it gets repaired I will re-post what the problem was. Still love the machine WHEN IT SEWS!!
Posted on Nov 16, 2008
SOURCE: Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Posted on Feb 14, 2009
  • 192 Answers
SOURCE: My Husqvarna Prism 990 only sews in reverse.
You could have an electronic problem on the main printed circuit board or in the feed length stepper motor. You may also just have a bound section in the feed mechanism. I don't think there is a cure all answer for this problem.
A 1/2 second hesitation between depressing the foot control and motor response is very common in these machines
If your husband lubricated the bushings on the upper and lower shafts of your 990 I recommend that you have him remove all of the lubricant possible and keep your fingers crossed. The 990 is a self-lubricating machine and applying machine oil to these bushing will probably cause them to seize. The 990 should never be lubricated in many of the places you would lubricate many machines. Hopefully, you haven't done irreparable damage.
Posted on Apr 23, 2009
  • 371 Answers
SOURCE: I need the instruction manual for a Husqvarna 1050 sewing machine
Checking with an authorized Husqvarna Viking dealer. They should be able to order a replacement manual from Viking for you. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
Why as the memory card suddenly stop working in the brother innov.is 750e embirody
Could be unseated or hit with static. Try reseating the memory or order new memory.
May 02, 2016 | Brother Sewing Machines
Struggling to decide which Brother machine for sewing, embroidery, and quilting.
The brother machine software may not be compatible with other scanner's software.
Jul 01, 2015 | Brother Sewing Machines
Brother innovis le cant get scanned picture off previous design
Hello Tarakeira
Here is an electronic manual at
http://www.manualagent.com/brother/innov-is-750e/users-manual/page-10
It is for for the 750E, but will be useful for your instance.
Happy Sewing
Apr 30, 2015 | Brother Sewing Machines
How to retime a brother 900d sewing machine
Breaking threads isn't necessarily a timing problem. Check for burrs.
Nov 11, 2012 | Brother Innov-Is 900 Sewing Machine
Monogramming
Hi there!
Bit of a con eh?
Is it the Innov-is 700E ? as featured here?
http://www.brothersew.co.uk/brother-innov-is-700e-embroidery-machine-193.html
Most machines can embroider.
The foot advance claw need to be disengaged, then a frame is needed to hold the material flat.
Select a zig-zag stitch, mark out your pattern and away you go!
Basically filling in your marked design with zig-zag stitch.
If it is the computerised version - ask the store for a demonstration.
Hope this helps, If so , rate as fixya!
if not - ask and I'll do the best I can.
Thanks for using Fixya! (I don't get paid for this you know. I just like helping folk)
Jun 13, 2008 | Kenmore 15218 Mechanical Sewing Machine
Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Apr 30, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
77 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
