Question about Whirlpool LER5636P Electric Dryer
Dryer does not heat most of the time
We have a gas dryer model # lgr4634jq1.once we set the dryer to a cycle,the knob does not move through that cycle and the dryer will run continually. the only setting that runs is the timed cycle but it does not heat (the dryer does not heat 90% of the time no matter what cycle it is set to). We checked the lint trap and it is clean. We have replaced the vent hose with hard flex pipe with 2 metal 90 degree hard pipe so there is no possible way that the hose is getting kinked. We vacumed out the exhaust on the back of the dryer. 10% of the time the igniter will light but it is so random that we are not sure what the problem is.
  • 640 Answers
Change your gas vavle coils..
Posted on Dec 26, 2008
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
Dryer timer knob
This control could be the problem IF the blower wheel ain't stripped, the dryer is clean, and the duct work is free of air restrictions.It is located on the blower housing next to the fuse.ec8cbee.jpg
Mar 18, 2010 | Maytag PYE2300AY Electric Dryer
Gas kenmore dryer
It could be a couple of things, but I would start with the flame sensor. Different models work differently.
Jan 03, 2010 | Kenmore 74962 Gas Dryer
Gas dryer not maintaining heat. The dryer heats at the start (after rest), and maintains the heat for about 15 minutes. After that, the dryer continues to tumble, but the dial (i.e. control timer knob)...
The problem is with the 2 little circular black coils next to the ignitor. They need to energize before the gas valve can open. They tend to get weak over time. I am 100% sure this is your problem. Good luck :)
Jul 14, 2009 | Washing Machines
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Dryer turns but no heat and knob doesn't move
Check the switch on the motor. It may have failed, or has a wire/terminal broken/disconnected. It is a multi-contact switch. both sections must click. Could also be mechanically loose on the motor and therefore just not getting fully activated.
Hope this is helpful.
Apr 04, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
MIGHT NNED A NEW IGNITER
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Mar 04, 2009 | Whirlpool LER5636P Electric Dryer
Roper Gas Dryer not heating.
Is the fuse on the picture is the one you bypassed:
The thermal fuse
- The wiring diagram which may help you.Here is information about prices n more elements that you may need.http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Thermostats-and-Fuses/index.aspx "Did I answer your question ?
Did it solve your problem?"
Jan 19, 2009 | Roper RGX4634KQ Gas Dryer
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
