Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5500 Printer Pa[per jam
After clearing the paper jam, the printer will not print in black.
  • md180 Dec 11, 2008
    Kodak will send you a new print head for free. They will also send more ink. If the print head gets hit wrong with paper or touched it goes bad. You will need a new one to fix the problem. Cleaning the head will not fix the problem.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Remove the printhead the recalibrate your printhead
Posted on Dec 29, 2009
    Problem Solver:
  • 15 Answers
Verify that the ink cartridges are intact and securely inserted into the printhead, then make the same print.
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If this will not correct the issue, try to follow these steps
Clean the printhead, then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. Press Menu.
  3. Select Clean Printhead, then press OK.
  4. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  5. When the On/Off light glows a steady green, select Print Demo Sheet, then pressStart.
If these steps will not correct the issue on the printout., you need to call Kodak technical support ( 1 800 421 6699) possible the printhead is defective and it needs to be replaced
Posted on Sep 29, 2009
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Kodak 5300 AiO Printer will not work due to paper jam
Looks like the sensor for paper jam is causing you problems.
Worst thing is that Kodak discontinued the whole 5xxx series because of all the problems those printers had.
I don't know if you will be able to fix the problem through Kodak support, I guess you will have to give them a call.
Good luck,
Milan
May 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5500 All In One Printer set up problem
If you are getting a 'carriage jam' error as soon as you turn on your Kodak printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t2952766-kodak_all_in_one_printer_paper_jam
Jan 02, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Paper jam and i can not find it
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Borderless printing kodak 5500, clear coating business cards
The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
  1. Click File , then Page Setup .
  2. In the Page Setup dialog box, click the Paper tab.
  3. Under Paper Size, select the appropriate borderless paper size.
To select borderless printing in the printer driver, follow the steps below.
  1. In the application, click File , and then click Print .
  2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
  3. Select the appropriate borderless paper size.
HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
Nov 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer
replace the ink cartridges first... could be just a cartridge issue...
do a print head cleaning... refer to your user's manual for step by step instructions on how to do a head cleaning on your printer.
Aug 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
141 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
