Question about Casio Watches
DW6800 cracking bezel
Need a parts DW6800 watch or a bezel in good shape. Watch does not have to work...just good bezel.
SOURCE: Bezel numbers are worn off
buy a new watch
Posted on Apr 11, 2009
  • 4 Answers
SOURCE: Where can I find Casio Watch spare parts? My watch
replica Watches
Posted on Sep 09, 2009
SOURCE: Replacement bezel for my Luminox 3003 watch?
you can try ebay for a used one for parts only. luminoxparts.com may have one if you email them. i may have one available, i will know in a couple of days. waiting on a replacement battery for mine. if the quartz movement is bad, than i will be willing to sell it for parts.
Posted on Apr 30, 2010
SOURCE: I need to change the bezel on an older Tag Formula 1
I'm sure any watchmaker can do it for you. I've had one pop off an old one for me an replace it with a slightly used one he had. I would like to replace that with a new one. They're available in the UK, but they're pricey. Ebay is an option.
Posted on Aug 20, 2010
gemineye61
  • 831 Answers
SOURCE: I bought a Versace DV
Thanks for contacting FixYa.
I am sorry. The only place to get a Versace replacment is thru Versace.
My only other advice would be to do an internet search and look for a less expensive replacement of the watch itself.
I know thats not what you want to hear. Best regards.
Jewel
Posted on Aug 28, 2010
The crystal of my wife's skagen watch popped out and the nylon ring surrounding the crystal seems too big to get back in, or perhaps I just don't have the right tools. Help!
Watch crystals are pressure fitted to their cases so that they are resistant to popping out. Think of a champagne cork, and how it expands when it comes out of its bottle.
Crystals are set into cases in one of several basic methods. First, a crystal may be installed from the back--watch cases are commonly assembled before the movement is installed. So, one potential way of reinstalling your crystal is to remove the watch movement from the case (if it isn't already) and try pushing the crystal from the back forwards. If this is indeed the way it was installed, the crystal should pop into position with a noticeable click or light thump to let you know that the other edge of the crystal has found the shallow groove in which it's supposed to sit.
Second, some crystals can be installed from the front using a tool called a "crystal lift." This tool has many little fingers that compress the edge of the watch crystal so that it can be slid into the case. Pressure is then gradually removed from the crystal, permitting it to expand into the shallow groove into which it's supposed to sit. Crystal lifts are easy to use in theory but somewhat finicky in real life; the crystal must be grabbed equally by all the lift prongs or else the crystal will have a tendency to squirt out of the tool before it's been completely set.
Looking at pictures of your wife's watch, it doesn't look to me like a crystal lift would do any good. I think instead that your crystal might have been installed using a third method. Looking at the pictures, it looks like the bezel--the metal top of the watch--separates from the watch body. If this is the case, gently pop off the bezel and push the crystal into it from behind. Then, push the bezel back onto the watch movement. It's possible that the crystal is kept in place by being squeezed between the bezel and the rest of the watch case.
If all of this sounds daunting, putting the crystal back in--assuming it's not cracked--is a minor job for a watch repair technician. It literally might only take 5-10 minutes to complete the job. If you're concerned about the appearance of the watch, it might be safest to pay someone the small amount of money to get this done right. Replacing a watch crystal with a new one usually runs about $15-25, around where I live. Replacing an undamaged crystal that's popped out should cost appreciably less, since a new crystal costs a jeweler between $5-25 for most standard sizes (diver's watches and strange specialty shapes will cost more).
May 16, 2011 | Skagen 358SSSD Wristwatch
I bought a Versace DV One White Ceramic watch. The bezel cracked and the Versace service center wanted $500 to fix. I think this is outrageous because I purchased the watch in May 2010 and the bezel is...
Jewel
Aug 28, 2010 | Versace Watches
Broken ratcheting bezel
mcdevito75 here, BEST BET for your Navy Seal watch, look for a small watch repair shop in your area for this part.
Jul 12, 2010 | Luminox Navy Seal Dive 3001 Wrist Watch
Need new bezel
Try parsecent.com, you can get a replacement bezel there...
and you are right, you are basically buying a new watch as this model is made of plastic and cannot be 'polished'. Refurbishing it means that it will look new and everything on the outside would have to be replaced...good luck :)
Aug 07, 2009 | Luminox Navy SEAL Dive 3901 Wrist Watch
My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Feb 09, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Replace bezel for omega seamater
I would recomend taking it to an independent watchmaker. It should only be $15, $30 to make the change.
Most bezels are pressure fit. Using a small jewelers knife to pry the bezel from the case is how most bezels are removed.
My friend is a watch maker and he has a special tool that removes the bezel however he told me he only uses it when he has customers watching. Because the old knife looks pretty brutial, but works better.
Dec 27, 2008 | Omega Seamaster 2541.80 Wrist Watch
Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
Dec 19, 2008 | Timex 1440 Nylon watch
Watches Logo
158 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
