Question about Panasonic Lumix DMC-FZ4 Digital Camera
Camera cannot be operated
I have used my DMC-FZ4 for almost 2 years and it was perfect. Since last week the camera cannot be operated. The battery is charged. When it is turned on, I can neither access the Menue nor Review of Delete buttons. The only button that operates - is the Shutter button, although it allows to take only one picture.
3 Suggested Answers
  • 11967 Answers
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Posted on Aug 23, 2009
damneddle
  • 1607 Answers
SOURCE: Panasonic Lumix digital camera DMC-F27
Hello
That is a sign of lens problem. Try gently - moderate tapping the camera repeatedly, with the lens facing the ground.
Posted on Sep 01, 2011
My camera wont turn on
The FS62 is about a three year old camera. If your battery is as old as the camera, I would highly suspect that is your problem (it's done, time for a new battery). Rechargeables are only meant to last a couple years max. Here's one, and here's another from Amazon (a little over 6 bucks with free shipping).
Dec 09, 2012 | Panasonic DMC-FS62 Digital Camera
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
Camera won't turn on
check the age of the batteries bc my rechargeable ones only lasted 4 years and they wouldnt even hold a charge for a couple of pics
Aug 15, 2012 | Panasonic Lumix DMC-FP3 Digital Camera
How can I charge Pamasonic DMC FS16 camera without having the charger with me. I'm on holiday and left my charger at home. I hoped the battery would last for a week,. A bit disappointed.
You can try plugging in the usb cable to your laptop, or any usb port really but the documentation is unclear whether that will actually charge the battery.
Really the only other really viable option is to find a camera shop, walgreens or tech store that could possibly carry the charger, or at least a spare battery.
May 26, 2012 | Panasonic Cameras
How to charge samsung lumix dmc fs16 without charger
May 26, 2012 | Panasonic Lumix DMC-FH2 / DMC-FS16 Digital...
Panasonic Lumix DMC-TZ3 Digital Camera: The camera LCD display is extremely dark with shadows/outlines of reddish pink hues and the same image is shown when a picture is taken. I have tried transferring...
Did u check the settings of the camcorder? see the setting there you got contrast settings if its low then you'll get dark images or its exposer meter's problem U check the exposer meter's reading and see aparture also.
Mar 09, 2011 | Cameras
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC-FX33 has operated perfectly for 3 + years. Suddenly, when turning on, camera displays message "Please turn camera off and then on again". Lens cluster 'twitches' but does not extend out....
Hello. If you suspect this is a lens problem ,I agree. I've had good results tapping the camera into the palm of my hand while its trying to open. Also try conecting your transfer cable to the camera and then press the power button, this keeps the viewing screen turned off sending full power to the lens mechanism. Lastly,and I should have mentioned it first,If you have a piece of exposed photo film,cut a small strip and work it in the gaps between the lens barrels to try to remove anything which may be stuck in there
builderdale
Jan 13, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Panasonic DMC-FX07 Digital Camera won't turn on.
Check your batteries, but otherwise it could be a power board. It could cost between $90 - $125 to replace the board
Dec 31, 2008 | Panasonic DMC-FX07 Digital Camera
Panasonic Lumix DMC-FZ4 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
