Question about Garden
Poulan 295 chainsaw won't start when warm
I have a Poulan 295 chainsaw that starts just fine the first time but once it has warmed up and you shut it off or if it dies and you try to start it back up it will not start. Leave it for a couple of hours and it will start again.
  • 211 Answers
Hi
Check the spark plug first (when the engine has warmed and died).If you have a good spark,check the fuel pump from the carb(it shuld not to be tighten).If everything is ok check the seals(they are sealing the engine).Good luck!
savumihai71
Posted on Dec 11, 2008
I HAVE A NEWER POULAN PRO CHAINSAW.STARTS AND RUNS FINE FOR 10-15 min. THEN DIES AND WON'T RESTART UNTILL COLD. THEN IT REPEATS THE SAME PROBLEM.
If it pulls easier than it used to when you try to start, you have low compression. Once the saw warms up, it doesn't have enough compression to run. If that's the case, there is no easy fix, it needs piston rings.
Dec 11, 2016 | Poulan Garden
Poulan chainsaw starts but won't stay running
Try choking it a little longer and it will warm up and should run
Jul 25, 2016 | Poulan Garden
2006 Poulan-Pro 295. Very hard to pull cord to start...feels like too much compression.
Remove the plug and try it. If its still hard to turn over. you may have cylinder damage.
Mar 12, 2012 | Poulan Garden
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 295 46cc chainsaw that won't start
Does the spark plug get wet with fuel when pulled through? If dry, try spraying a little starting fluid in the plug hole and reinstall the plug. If it pops at least once, you have fuel delivery problems--look for hardened/ cracked fuel lines. Clean the muffler arrestor screen. When the muffler is off, check the condition of the piston skirt and cylinder wall for deep scoring or obvious wear. Make sure the primer button (if equipped) is filling with fuel when pumped a few times. If it doesn't, make sure the bulb is not hard or cracked and check the lines going to and from it. Check the carburetor bolts and nuts for tightness. The fuel filter in the tank could be plugged, fish it out and check. If you have checked all these items, it may be time to clean and rekit the carburetor. Hope this helps!
Mar 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 295 Pro won't start. Changed gas and
I suspect the carburetor is full of remnants of the same fluids you found in the tank. If it was my saw I'd take it to the local Stihl dealer for an estimate to repair. I'd expect to pay $40 - 80 for a tune up and repair depending on how many fuel hoses must be replaced. HTH
Lou
Oct 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My Poulan chainsaw is hard to start and will not re-start once it is warm. Any suggestions besides junk it.
Spend $ 40 for a tune up at a local chainsaw seller/mechanic. Most Stihl outlets are very good. It sounds like carburation needs adjustment, but they also do a good visual inspection. Mine get done about every 3 years worth of use. HTH
Lou
Sep 29, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
854 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
