Question about Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 GPS
The voice on my GPS is not working
  • 2 more comments
  • Anonymous Dec 19, 2007
    I just upgraded my system version from a 3.20 to a 3.22, wish i never did because , my sound does nit work now, everything thing else does, what could be wrong
  • lost nomad Dec 22, 2007
    i had 3.2 verison i was going to update my maps but they said i first had to update to 3.32 .after doing that i have no sound at all .they said they no longer service the 700
  • mcseorly Jan 17, 2008
    I am having the same problem with my magellan roadmate 700. I had ver. 3.10 and upgraded to ver. 3.22 so that I could install the new software and maps ver. 6. The unit was working perfect before the update, but after I lost all sound. I tried removing the power and reseting the sysem with no success. I was looking for information and came across this post. I found the hidden menu (- and Repeat) But what am I supposed to do once i am there.
    Thank in advance.
  • Sherileed Jul 31, 2008
    Same here. Just updated to 3.34 last night and now no sound.
    Problem Solver:
  • 6 Answers
1. Search for the file ENG_F.SND sound on google or yahoo or any search engine.
2. Connect RM 700 to PC, and create folder name SOUND_EU on RM 700.
3. Copy the ENG_F.SND to SOUND_EU folder.
4. Disconnect RM 700 from PC.
5. Turn on RM 700, and go to Option, configuration, language, and choose English.
6. RM 700 will load sound file and turn off.
7. Turn on RM 700, if it keeps showing the initial screen, then connect the RM 700 to PC, and DELETE the ENG_F.SND from SOUND_EU. It should be OK after you disconnect RM 700 from PC and turn it on again.
GOOD LUCK!
NOTES: My screen indeed locked at first as covered in the last step, so expect that to happen. Don't worry if you never get to do step 5 and 6. Connecting the USB, deleting the SND file and restarting it works and the sound is back even without the file there.
This only fixes the Female voice along with the beeps and clicks. The unit goes silent again if you select the male voice but switching back to the female fixed that. I assume "_F" in the file name must mean female.
The display still shows "AFIJDEN...." or something like that instead of the word Exit or Entrance when exiting or entering the freeway. Voice is fine though. Anyone got a fix for that?
Posted on Jun 20, 2008
    New Friend:
  • 24 Answers
  • Turn on the unit and select any user.
  • Push 'Option' button.
  • Then select 'Configuration' on the screen.
  • Scroll down to select 'Diagnostics'.
  • Scroll down again and select 'AUDIO Test '.
If you can hear any sound in the 'AUDIO TEST', it implies that there is
No issue with the SPEAKERS. You can turn the volume control to MAX
and try to obtain sound. Sometimes you would also have to depress the volume dial and then rotate it to increase the volume.
However, if you cannot hear any sound in the AUDIO test, it would imply that there is a problem with SPEAKERS.
Posted on Jan 27, 2008
Hi dan my uncel has a 700 with no sound at all can you help me so i can help him , thanks larry.
larryh5540@aol.com
Posted on Jan 24, 2008
    Novelist:
    Scholar:
  • 86 Answers
Assuming that it is just the voice not working and not all sound in general, try going into the configuration menu and do the voice tests, run the audio test ("a - b -c" etc. ) Do you still have the clicking sounds. If you have the software version (4.32/5.14 or 5.32) that came with your unit, then re-install it. If your not getting any sound then let me know and I'll tell you how we can fix that.
Posted on Mar 15, 2007
3 Suggested Answers
SOURCE:
DanEz007
  • 86 Answers
SOURCE: RoadMate 700 GPS is not working..
Does the initial Magellan screen appear? If it doesn't display anything and it's just blue... :( Normally means that something on the main board is your problem. Which, means your out of luck. What happened to it? It just suddenly stopped working? Let me know. R/
Posted on Sep 19, 2006
DanEz007
  • 86 Answers
SOURCE: Magellan RoadMate 700 GPS unlockmap
Steve, In this case I would replace the Hard drive. But, since you probably don't have spare HDD's lying around.. do you atleast have the Software version? Some CD that came with it hopefully. If you do, then you may be able to stay alive here. Once your system boots to the user screen.. press + and repeat key at the same time.. "secret" menu now. ONLY IF YOU HAVE SOFTWARE TO INSTALL!! Select NAND FLASH FORMAT.. The unit will shut down after formatting. start up your software installer on computer. plug usb in.. and power on unit. This fix isn't %100, but it's the best shot you have. Otherwise you've gotta send it down here to Texas (where magellan repair is) and pay for the new hard drive. OR.. you could call customer service and see what they have to say. you'll probably be transferred to overseas.. --good luck with that -Dan
Posted on Feb 10, 2007
Can the previous owners name be removed from a Magellan RoadMate
Sure. Consult page 59 of the user manual for instructions on how to do it. Here is the link for the manual. Magellan RoadMate 700 GPS Manual.
Feb 04, 2013 | Magellan RoadMate 700 GPS Receiver
I have magellan 700 roadmate .it is not take signal.it just search and search.
I woud do a reset on the gps device....I have attached a link to the manual for the Roadmate 700....http://www.starbatteries.com/maro700vegps.html
You are going to look for this
Magellan RoadMate 700 Vehicle GPS View the product manual [Download- PDF, 1MB]
Good Luck
cbinny1
Oct 20, 2008 | Magellan GPS
Magellan roadmate 700
go to the magellan website and all your answers are there.
Sep 13, 2008 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Speaker voice is distorted. need new speaker.
take the old one out and try going to a radio shack store to match it or call the company magellan and see how much and to ship it
Dec 17, 2007 | Magellan RoadMate 700 GPS Receiver
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
If everything else is working fine, specifically the touch screen, then it's probably your speaker. open unit and check your speaker for anything stuck to the back of the magnet (on the speaker). make sure the cable going from your speaker to the keypad PCB (board) is pushed in all the way. you may want to even pull it out and re-connect it. make sure the unit is off while you do this and try to ground yourself with something. good luck and let me know how it turns out.
Mar 04, 2007 | Magellan RoadMate 700 GPS Receiver
Sep 17, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
706 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
