Question about Nokia 2600
Nokia 2600 time display
I need to display the time on my Nokia 2600 phone. I have selected "Show" under Time & Date Settings. When I browse through menus, the time displays in the upper right-hand corner. However, when I exit to the main display screen, the time disappears. Please help, thanks!
  • 1 more comment
  • lazyeyesamur Dec 25, 2008
    The phone will not show time on standby mode. It will show date, but not time.
  • Anonymous Dec 31, 2008
    same issue. I've even gone through tuturials to try and get a clock on display always. no juice. totally pissed at AT&T for leaving me with no other choice than this phone.
  • noworkynokia May 11, 2009
    When I first got the phone it showed the time always, but now only when looking at other menus or when the screensaver is ghosting out.... totally frustrating since I need the clock all the time!
I'm a cell phone sales representative and I came across a customer that had a similar problem.
What I found with her, she had so many icons displayed along the top row of the phone that the phone simply did not have room to display the time.
By clearing out her text message inbox, the sent messages, the outbox and being sure all of her voicemails had been checked, a number of the icons disappeared off the top of the screen and so the phone started to display the time again.
So that solve the problem for her. Hopefully it can help you as well.
Posted on Jul 08, 2009
How to hide time on to display on nokia 2690
Hello there,
To hide the times display on the nokia 2690, simply go to the menu, select the settings, then you scroll to date and time, in date and time scroll to date and time format settings, in the date and time format settings select time, when you open the page you will see clock and 12-hours or 24 hours depending on what time format you are using, select clock, you will see show time and hide time, select hide time.
All the best Elect_Comp
Sep 15, 2011 | Nokia 2690 Cell Phone
Tip
Nokia Tips
`Your Nokia cell phone can be programmed to pick up radar speed traps, when programmed your cell phone picks up the radar and alerts you on the message alert tone. 1. Enter your menu 2. Select settings 3. Select security settings 4. Select closed user group 5. Select on 6. Enter 00000 7. Press ok 8. Clear back to normal, within a few seconds your phone will display a radar sign with five zero's next to it. It is now activated. Unfortunately only Nokia phones have this function. Cell info display needs to be de-activated. Settings -> Phone Settings -> Cell Info display Each time you turn off your phone, or even each time you loose contact with your carrier, you´ll have to activate it again... It is done by steps 1 through 5, but the number (00000) will be already on the field as default. If you put the number 500 in the closed user group, and you go out of a store with detection ports thy will go off. Firmware version: *#0000# *#51x0# or *#9999# View Serial No., Date Made, Programming Date, Repaired: *#92772689# Thanks to Ben-Dov for this code IMEI (International Mobile Equipment Identity) Code: *#06# Enhanced Full Rate (EFR): *3370# to activate EFR. Makes calls sound better, but decreases battery life by about 5%. #3370# to deactivate EFR Half Rate Mode (HFR): *4720# to activate HFR. Decreases call quality but increases battery life by about 30%. #4270# to deactivate HFR. Default Security Code: 12345 Warranty Code: *#92702689# [*#war0anty#] asks warranty code. You can then type a number of codes (Thanks to Mike Pfaff for these codes): 6232 - Display date of manufacture 7332 - Display date of last repair 7832 - Display purchasing date 9268 - Display serial number 37832 - Set purchasing date to MMYY 87267 - Confirm Transfer, Related to firmware upgrades #746025625# says SIM CLOCK STOP ALLOWED or similar, depending on your SIM card. Newer SIMs have a feature called 'clock stopping' that allows the phone to save energy -- it is a kind of sleep mode for SIM cards. Not all versions of software support this. You cannot turn the SIM clock on and off, the phone will do it automatically if the SIM supports clock stopping.
on May 20, 2010 | Cell Phones
Tip
Nokia
1. Enter your menu
2. Select settings
5. Select on
6. Enter 00000
7. Press ok
Firmware version:
*#0000#
*#51x0# or
*#9999#
*#92772689#
*#06#
12345
Warranty Code:
on Dec 09, 2009 | Cell Phones
How do I change the Date and Time displayed?
You log into the Phone administrator settings, Go to General, Select Date and Time and correct them for the entire phone system.
To Log Into System Programming:
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
4. Press Show
5. Select Date and Time and Press Show Correct Date and Time then press release. Let me know if you have any other questions.
May 16, 2011 | Meridian M9316 Corded Phone
How delete time display from screen for nokia 2690
Settings-->Date n time-->Date n time format settings-->Time-->Clock--> (show clock/hide clock) !!
Mar 26, 2011 | Nokia 2690 Cell Phone
How do i set the display on my phone so it says time and date
this is very easy.take the 'settings' from menu.then 'date and time settings'.from this select 'show date and time' or similiar options.
Sep 17, 2010 | Cell Phones
On my 6300 nokia how do i get it to screen save with thatfaint grey horiontal line of time and date that moves down the screen over time
Go to the settings select display settings, then select screen saver, again select screen saver from the list and then select the type of clock you want
Mar 03, 2010 | Nokia 6300 Cellular Phone
Panasonic KX-TG8423E Time & date display issue...
Same thing happened to me on one of the phones but if you go into display setup you can choose the wallpaper with time and date showing or without. You need to choose the - with time showing on each phone individually.
Jan 10, 2010 | Panasonic Lands Phones
I m using nokia 2330c-2 how can i remove display clock or hide
Hey,
You can refer the manual from the link below http://nds1.nokia.com/phones/files/guides/Nokia_2330_classic_en.pdf
Go to display settings and then Power saver clock you can select Digital clock, Classic clock or Off
Let me know if this will help
Regards
Nov 26, 2009 | Nokia Cell Phones
Display time and date
Go to your phone's "Time & date" settings and select "show", u might have your date and time hidden this time. And more thing, set the time and date first, some phones displays time and date automatically after setting...unless the user choosed to hide it...good luck! i hope this solution solved your problem.......
Oct 09, 2008 | Motorola Mobility RAZR V3
Nokia 2600 Logo
571 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
