Question about Whirlpool LSR8233J
My whirlpool top load washer wont spin
It will fill up with water the dont do anything else
  • leelippincot Dec 14, 2008
    I have a similar issue will not wash or spin can hear the motor. If it is the coupling how hard is it to fix?
  • 71 Answers
If you can hear the motor , the problem is the coupling . no sound most common is the motor or capacitor on motor
Posted on Dec 12, 2008
  • flyingtarzan Dec 15, 2008
    about a hour or more depending on if you know what you are doing. I can help you .
My whirlpool thin twin washer wont agitate it just makes loud sound but will fill up with water
Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
1485646-1-s-jpg.jpgSee Part # 13
Search all parts
in this section
USE WPL 285753 (Direct Drive Motor Coupling)Part Number: PS1485646
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength.
CAD$12.81
Oct 24, 2012 | Whirlpool LTE6234D Top Load Stacked...
My washer wont spin run do anything says f 55
It's a control board issue,this unit is made by Whirlpool,they are repairing a lot of theirs for free,so you may want to call Sears and see if they are covering theirs also.
Sep 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Doesn't drain or spin
Hello there,
If it doesn't spin or drain, you probably have a bad lid switch. If the machine fills up with water and does not do anything after then it's the lid switch.
Best of luck to you.
Apr 11, 2009 | Whirlpool LXR9445JT Top Load Washer
Washer wont work
If the motor is running but no agitation or spin is happening, then most likely the coupling between motor and gearbox has gone- look for black sooty deposits under your washer as proof. There may also be one or more pieces of white plastic. This coupling usually goes if the washer is overloaded regularly.
Dec 29, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Wont fill with water
I probably has a bad fill valve or a clogged screen suggest check to see if the fill valve is engaging and if there is water getter past the valve.
Jan 20, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
