Question about Canon PowerShot A75 Digital Camera
Camera shows an error E30 message
When i tried to turn on the camera the display showed E30 which i later found out from the manual is an error message.This messaga showed up only once.After this happened whenever i tried to turnon the camera,it would be on only for a while(about 4to 5 seconds) and then it would turn off.This repeats whenever i turn on the camera.What could have gone wrong?
  • avinash puranik Mar 10, 2007
    Hi Dinoza,
    Thank you very much for the suggestion.Since i dont have a spare memory card,I must buy another one or borrow it from someone.As soon as I test the camera with a new memory card,I will certainly let you know.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Hi Chittu, This error usually happens when there's problem reading and writing from the Flash memory card (CF). Did you try to pull the memory card before the camera finished writing data? Here's what you should do - try using another memory card. If it works, it means that the original one is damaged. Let me know if this helped. Please rank this post.
Posted on Mar 10, 2007
  • Dinoza
    Dinoza Mar 11, 2007
    Thanks for your comment and ranking.
    Good luck.
Error message-no images
Try taking any image, save then, see if the if you still get error message
Nov 05, 2017 | Polaroid i737 Digital Camera
Wat do;s Err-80 meen
Looked up on Canon.es and this is what I found.
FAQ: What does the error code 'Exx'?
FAQ ID: 44574
Last Modified: 22-Jan-09
Cause
Answer:
When an error occurs the camera will display an error code like "Exx", where "x" represent numbers.
See the list items at the bottom of this page when it shows following error codes.
"E18" error of the target unit / lens barrel
"E30" and "E50" error of the CF or SD card
When an error code "Exx" different from those already mentioned, the camera off and then turn to try to capture or play back images.
If this error persists or an error code appears often, there was a malfunction of the camera.
Note the error code and contact the retailer where you purchased the camera or the nearest service center for Canon.
I hope this helps
Jan 24, 2012 | Canon EOS-D30 35mm SLR Camera
When switched on my pc it will display error messaga . That is "error 912 the machine cover has been removed since last system is start up"
This error is displayed if chassis intrusion protection is enabled and the cover is removed.
But as I remember you can bypass this message and start the computer. I don't remember the key, but try Escape or Enter key. (I think the button to skip this error is displayed below the message).
You can also go to BIOS and disabled Chassis intrusion detection.
Sep 05, 2011 | HP Compaq Presario SR2011WM PC Desktop
The display screen shows " file error " only.
The manual can be viewed here:
http://www.fixya.com/support/p228383-toshiba_pdr_m4_digital_camera/manual-5928
I don't see anything about a file error message, though....
Have you tried using a different memory card, or formatting the one you have?
Jul 01, 2011 | Toshiba PDR-M4 Digital Camera
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
When i turn on, it says lens error, restart camera - i"ve turned the camera on and off several times and nothing happens, the error message continues to show. I've taken the battery out and put back in but...
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 05, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
When I try to turn the camera on, shows message "retry power on"
hola no tengo driver de la camara como puedo vajarlos largan chameleon
Jul 06, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Pentax mz 60 unable to load film error message
error messages are for camera repair technicians and are found in repair manuals. have your camera checked by a camera repair shop tech.i would get an estimate first.
Dec 15, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Error message
try Klomtrix trick this worked with my camera thanks klomtrix
Oct 25, 2008 | Panasonic Lumix DMC-LC33 Digital Camera
Canon PowerShot A75 Digital Camera Logo
121 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
