Question about Polaroid FLM-323B Television
No signal when hooking up to dish network.
When trying to hook up second tv on dish network I cannot get a signal.It is a wireless connection from the satelite box.The other tv I am using gets a signal. The tv is a lcd 37 inch polaroid.I do have a cable from the satelite box going into the tv.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Posted on Dec 12, 2008
Keeps saying no signal, but have it hooked to my dish network antenna
Please check whether you have selected the correct input from the remote control. Secondly connect the input to some other TV and ensure that there is signal.
Jul 12, 2012 | iLO Televison & Video
How do you hook this TV up to a standard Dish network system. We are trying to hook it up and it says no signal.
Hello there! My name is Becki, and I am with DISH Network. I do hope that this has been resolved for you! But if not, here are some steps that you can try. I hope this helps!
You will first want to put your TV on channel 3.
You can use RCA (red/white/yellow) cables to hook up the receiver to the TV.
If you are using a receiver that works 2 rooms, on the back of the receiver, the location for the RCA cables will have a green TV symbol with a 1 on it. That is where you want to connect these cables. Run these then to your TV. Some TVs will give you an input number next to these connections, such as Video 1 or 2.
After these are connected, try to cycle the inputs on your TV. You can do this with the buttons on the side of the TV, or with the remote. Go slow, becuase it can take a few seconds for the input to actually change. If this does not work, try to go to channel 4 and repeat the steps.
You could also use coax cable to connect from your receiver to the TV. The connection on the back of the receiver will simply say channel 3/4. And that is just what you do, put the TV on channel 3 or 4.
If these steps do not work, or you need some clarification, please let me know!
Becki Barned
DISH Network Customer Service
Jul 24, 2011 | Vizio VW26L 26 in. LCD TV
How do u hook up the dvd player and dish network to your tv
If you have HD TV it is best to hook up the DVD player separately.
The easiest way to connect your DVD player with your TV, is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. Once you've done this make sure your TV set is tuned to the proper input or source. Your DVD's should play when the receiver is off, however, you'll probably need your DVD player on to get the DISH signal.
Daniel Busa
Dec 10, 2010 | Sanyo DWM400 DVD Player
I have Dish network. I want to record TV onto the VCR, but cannot get channels to record. i can playback videotapes and the record works, but cannot figure out how to get the signal to record.
The output of the Dish Network box should be hooked to the input of the VCR.
The output of the VCR should be hooked to the input of the TV.
The VCR should be on channel 3 to record. Select channel to be recorded on the Dish Network box.
It sounds like you have Dish Network box output hooked to TV input.
& VCR output hooked to an aux. input on the TV.
Nov 28, 2010 | Quasar VHQ401 VHS VCR
I have a 20 inch sanyo hd digital hooked up as a second tv on dish network receiver. I had to unhook it temp and when I hooked it back up, no picture. I tried channel scan and nothing. How can I get the tv...
bring the tv out to the main tv and hook it up to that connection to determine if it's the TV or the connection. Or try hooking up a VCR to the tv while the TV is set to CH 3. Do you get a blank picture or a snowy Picture?
Sep 20, 2009 | Sanyo Televison & Video
No TV signal
If it's hooked to Dish network, you have a receiver to connect to the TV. If you're using the receiver's RF output on channel 3 or 4 to the TV's antenna jack, you need to have the receiver on while the TV is scanning or it won't add the receiver's output channel. You can rescan channels after you turn the receiver on. If the TV has AV input jacks and you're connecting the receiver that way, you need to switch the TV to the AV input. That may be difficult or even impossible without the TV remote.
May 04, 2009 | Televison & Video
Digital signal
hi my name is mark, if you are already hooked to dish network, there is nothing you have to do. you are ready fotr the dtv change over june 12 09
Aug 17, 2008 | Protron PLTV-32 Television
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
Hooking up tv to dvd player
You will probably have to use your tv remote and change the input for your dvd. It's usually video 1,2 or component 1,or 2
Jul 01, 2007 | Insignia IS-LCDTV32 32 in. Television
Polaroid FLM-323B Television Logo
359 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
