Question about Tappan TGF320 Gas Kitchen Range
Glass top is scratched no matter what I do. oven doesn't work ri
Glass top is scratched no matter what I do. I bought special cleaner and still scratching, I cannot can on this stove because of scratching. Oven temperature isn't correct.
I had my other stove 15 years and it was a whirlpool.
  • 318 Answers
Glass top stoves are not designed to do canning on, sorry. the only thing you can do for the top is that special cleaner as it has a "wax" in it and will help to prevent stains, but not scratches.
remember your top is glass and it will scratch.
your oven can be calibrated to help it to bake better. what you need to do is make sure you have a temperature problem that can be corrected by calibration. try to just set the oven temps up or down 10 or 20 degrees and try to bake the same items. if this helps then you can reset the calibration of the control as per your owners manual, if you dont have one then i can tell you how if you can tell me the brand and model.
Posted on Jan 15, 2009
White scratches on top of amana cooktop
So, your pot scatched the surface of your glas top?
Stop using those pots.
You can repair scatched glass with a very fine "sanding paper", similar to those used to repair the crystal of a watch or reading glass but you should get help form someone who really knows what he is doing
Aug 15, 2015 | Amana Kitchen Ranges
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
I have black swirl scratches from using abrasive sponge on front of black oven door
There is this white stuff sold for glass-top stoves. I presume it is good old iron cleaner, a very mild cleaner/polish. Also consider toothpaste.
Dec 01, 2013 | Amana 30" Self Cleaning Electric Range...
I have a scratch on the top of my ceramic stovetop. How can I repair it?
Instructions for repairing scratches on ceramic cooktop
Things You'll Need:
  • Nonabrasive cleaner
  • Dishwashing liquid
  • Cloth
  • Razor scraper
  • Ceramic crème
  • Sponge or cloth(s)
  1. 1 Clean the cooktop with a nonabrasive cleaner, such as a glass cleaner or warm water mixed with a few drops of dishwashing liquid. Wipe with a clean, soft cloth.
  2. 2 Use your fingernail or the flat edge of a razor scraper to remove any raised surfaces on the scratch.
  3. 3 Apply a ceramic repair crème, available at most hardware or home repair stores, to the scratched area. Work in gently with a soft cloth or sponge.
  4. 4 Allow the crème to sit for 15 to 20 minutes. Wipe away with a clean, damp, soft cloth.
  5. 5 Repeat as necessary until the scratch is no longer visible.
Nov 10, 2010 | KitchenAid Microwave Ovens
How/what can be used to clean range ''glass top'' can those green spunges be used/
Oven cleaner, use EASY-OFF Fume Free Oven Cleaner, it is the best
for cooked stains.
You should not use anything but a soft cloth, and if you use the cleaner
you won't need something abrasive.
Once you put tiny scratches into the glass, it will be more difficult to clean.
After you clean it with oven cleaner, rinse it with a warm wash cloth a few times, to make sure no cleaner is left behind, and read the directions.
Feb 11, 2010 | Amana ARDS802 Electric Kitchen Range
Can I use an abrasive cleaner on the inside glass of my oven door?
I wouldn't do that. I think it would scratch it. I have had good luck using that Mr. Clean pad on my glass stove top without scratching it.
Nov 19, 2009 | Smeg Ovens
I have a glass top gemini maytag, the top is white I have tried many cleaning products but cannot get it clean.
I used Cerama Bryte cooktop cleaner that I bought at Bed Bath & Beyond. It comes with a scraper and a special scratch pad. I applied it has directed and let it dry on the cooled cooktop and all the burn marks and baked on stuff wiped right off the cooktop. I make sure I use it about once a week and the cooktop stays looking good.
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Scratches on glass stove
Is it glass or ceramic? there are special cleaners for ceramic tops check walmart, lowes, or where ever you bought that one they can tell you.
Aug 25, 2009 | Frigidaire FEF366 Electric Kitchen Range
Burnt sugar caramelized on a Jenn-Aire glass cook top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuuf really works
Mar 14, 2009 | Jenn-Air JJW8230D Electric Double Oven
Scratches
a ceramic cooktop cleaner , adn a terrycloth towels, working in small circular motins you should be able to "lessen" the visiblity of the scratches, probly no t remove all together but lessen them anyway. watch the pots your using, no glass or ceramic pans, they will scratch every time and try to llift the pot to remove it and resist the temptation to slide and twist pot during operation
Jul 08, 2008 | Ovens
Tappan TGF320 Gas Kitchen Range Logo
495 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
