Question about Garmin GPS
NEW PURCHASE AND PLUGGED INTO AUTO TURNED ON AND GARMIN LOGO APPEARED AND THEN SCREEN WENT BLACK. DOES NOT WANT TO STAY ON. INTSTRUCTIONS SAY UNIT WILL PROMPT BUT NOTHING HAPPENS. IS THERE SOMETHING ELSE THAT NEEDS DONE. DOES UNIT NEED TO BE CHARGED FOR A PERIOD OF TIME?
  • Garmin Master
  • 2,124 Answers
Yes!!! Please charge the unit overnight. You didn't say what model you have. If it's a 2xx series, plug in the charger and move the on/off switch momentarily to the left until you see the screen say charging. Set the unit down and the screen will go off. If you touch the screen again, it will come on. After charging is done, when you touch the screen it will say charging is complete. Remove the charger. If its' a 3xx or 6xx product, hold down the on/off power button until you get the charge screen.
- Jim
SHARCNET-USA
Posted on Dec 11, 2008
Hi! I bought a new asus eb1505 4GB RAM 500G disc. I switched it on, it asked me for some settings (language, EULA etc.), I set an username and a password. Than it said it should restart. Ok. After...
What I would do is to on post pressing your PC's power on begin to click over and over till you see a screen the F8 key. Go into Safe Mode or you may be able to Start Windows Normally. If this does not work then you must either do a Recovery or Run Windows disk.
Aug 30, 2013 | ASUS EeeBox PC EB1505-B011M Intel Celeron...
After charging my nuvi 1450LMT for four hours, I disconnected it from the power cord and left it overnight. When I turned it on the next morning, I got the Garmin logo, then a white screen flashed on...
How did you charge it? If you did not use a high power USB charger, try that overnight. A USB charger provides a lot more powr than your PC. Leave it plugged in and off overnight.
If that does not work, Amazon sells battery replacement kits.
Apr 09, 2017 | Garmin Nuvi 1450LMT
My Garmin nuvi 780 will not turn on. When I turn on, the Garmin logo shows on the screen. However, when "Loading Maps" is displayed, 1-2 seconds later the screen goes blank. This occurs when the unit is...
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Apr 03, 2010 | Garmin nuvi 780 GPS
I turned my Garmin on and just the black screen appeared and never loaded to the home screen
You might try a couple of things:
1. Do a hard reset on the unit by holding the power button in the ON position until it restarts. It could be that your unit was left in a funky state when last you used it.
2. Plug it in to your computer (it will connect as if it were a storage device), go through all the registration stuff with Garmin.com, and download any software updates that are outstanding. That should clear things up.
Mar 16, 2010 | Garmin nuvi 255W GPS Receiver
Black Screen to no power
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Blank Screen on Garmin C330
It took a nap...
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
IS the battery charged fully? Try turning it on while its plugged in.
Oct 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Wont turn on
Question: Why won't my unit charge while plugged into my vehicle?
From the Garmin site: --> Answer: If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece. fileservlet?date=1&kb={6b85cfa0-194d-11dc-44cd-000000000000}&id={6e53bea0-6874-11dd-436f-000000000000}&ext=jpg
  2. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  3. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
fileservlet?date=1&kb={6b85cfa0-194d-11dc-44cd-000000000000}&id={6e476290-6874-11dd-436f-000000000000}&ext=jpg //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 08/12/2008
Sep 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c550 GPS-Won't turn on at all.
could the battery be dead? Leave it to charge on the wall charger for several hours. Then try again. There is a way to do a hard reset....
Jun 08, 2008 | Garmin nuvi 350 GPS Receiver
NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
May 24, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
