Question about NAD Audio Players & Recorders
NAD 5425 CD Player display light out
Does this unit have a bulb backlighting the display? If so, how do I replace it?
  • 1,512 Answers
Hi aartman
Yes it does have backlamps.
They are soldered to the PCB so you will need a few tools like a soldering iron, philips screwdrivers, solder, and some replacement lamps. Replace the lamps with this type from Farnell electronics. They have a 15000 hr life expectancy and last alot longer in the unit. I have tried many types of lamps over the years, and found these are the best choice if you want them to last.
FOR YOUR SAFETY-BE SURE TO DISCONNECT FROM THE MAINS BEFORE REMOVING THE LID
To get access to the lamps, you need to pull the main PCB out of the chassis to then get access to the bottom side of the printed circuit board where the 2 screws that retain the white lamp reflector assembly. Change both lamps with the type I mentioned,
NAD 5425 CD Player display light out - 6ab9edb.jpg Be careful not to flex the LCD display that is now exposed, it is quite fragile with the support of the lamp reflector cover no longer in place. ... reverse procedure to reassemble and away you go.
I am more than happy to talk about this solution with you further. Just ask away. Cheers
regards
robotek
Posted on Dec 12, 2008
  • Graeme Ross
    Graeme Ross Dec 12, 2008
    Oh and I should tell you that there are 2 lamps fitted in this unit(for when you go to order them). You can get to a Farnell site in your country here with an order code: SC00347
  • Lawrence Binns
    Lawrence Binns Apr 03, 2014
    HI Graeme I am buying a 5425 to replace the one I had for 25 years, want to swap out the faceplate of the display, is it easy to do? How does one do it? The faceplate on the one I am buying has sratches, I am going to replace with my existing one in the player that died...
2 Suggested Answers
SOURCE: NAD 5425 CD with dead backlight: ONE big bulb not 2
nope
Posted on Jul 15, 2009
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Jan 04, 2010 | NAD C521 CD Player
NAD CD 5425 - No Spin - Sometimes
I've dealt with this type issue quite a bit.
Believe it or not the drawer belt needs to be changed.
If the drawer isnt drawn all the way into the unit...the disc motor wont spin and ....you get rejected
Dec 23, 2008 | NAD C521 CD Player
Light doesnt work
hi...
Do you mean the Display?
If so ,it's a backlight issue. Some use little bulbs ( NAD and Yamaha)
Take it to a tech ( Ask your stereo store)
Oct 14, 2008 | Marantz CDR631 CD Recorder
Nad c520 high pitched ringing
Hi, From your description, it sounds as if the noise is coming from the circuit that controls the display backlight. If I recall correctly, the C520 has an EL backlight just like the C521 (which I have one of). On the front of the circuit board, there should be a little yellow trimmer potentiometer that controls the brightness of the display. It may be that the noise will go away if the brightness is turned down some. If  the noise varies as you turn the controller, but doesn't go away completely, the backlight may need servicing.
Aug 06, 2008 | NAD C521 CD Player
Display light
This is the backlight, bulb 9V. must be repaced, i suggest to replace by a 12V. bulb
Unit has to be disassembly. Good luck
Mar 03, 2008 | JVC RV-B55 Cassette/CD Boombox
NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
Sep 06, 2007 | Audio Players & Recorders
NAD 712 Stereo Receiver display
http://www.bulbdirect.com/ who's your mommy? ;]
Feb 01, 2006 | NAD 712
NAD C521 discs not spinning
The CD player has a sensor that is supposed to detect when a disc is inserted and spin it up etc. yours might be the problem, either it has some loose connections (that you haven't noticed) or it simply misbehaves. Another thing could be the motor itself that somehow 'misses' the spin up signal and needs a 'manual' boost. The best solution in your case is probably to bring it to some lab.
Sep 14, 2005 | NAD C521 CD Player
2,443 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
