Question about AudioBahn A4004T Car Audio Amplifier
Audiobahn A6004T Amp Blown PLEASE HELP!!
OK here we go I had a system installed last year and now my amp has blown. Here's what happened. I was driving my car listening to my music. I got to my destination and turned the car off. Only 15 minutes later I got back into my car and turned it on and I had no sound. I turned the car off and back on. Still nothing. I folded down the seat the look at the amps and smelt burnt wires. So I turned off all my stereo stuff and went home. I checked the fuses and both fuses were blown. So I replaced the fuses and the amp started smoking right away. (I did this before I cut the power to the amps) I took the amp out. I still have my other amp powering my subs in my car but I removed the fuses so there would no power to it while the other amp is out. I removed the case for the broken amp and saw this.....With the channel plugs and Audiobahn facing me...... on the left side there are several little black squares connected to the main board. The first 2 of these squares have 1 connector that is black. The squares have 3 connectors on the board. lined up like this - (farthest) - - (closest) Going into the board the one farthest from me on both squares are the black ones. Does anyone know what this part is? How to replace? and where I can find a new one to install? Also if there is anything else that should be replaced?
  • vlow6282028 May 01, 2008
    High My Name is vick and i was hooking up one of my friends systems and when i was done hooking the system we had tested the system out. and there was no sound coming from the speakers so i turned off the system. then i went to check the fuses in the back of the amp and they were blown so i changed the fuses and they blew again so i was hoping that you could tell me what is wrong with the amp
I just repaired this problem... the squares are indeed, MOSFET amps. I don't know the specs of the larger ones, but the smaller ones are FQP-50N06 N-Channel 60V 50A MOSFETs, manufactured by Fairchild Semiconductor. If you search for FQP-50N06 on a site like www.mouser.com or www.jameco.com, you can purchase replacements for about ~60-70c each.
I just removed the board, desoldered and removed the blown amps and replaced them with the new ones, and now the amp works. Do be warned though -- after you replace the MOSFETS, you might want to check that the amp isn't drawing power while it's turned off -- when you blow the amp, you might create an internal short-circuit that will drain the battery very quickly, even if the amp isn't on.
Posted on Apr 24, 2009
    Novelist:
    Champion:
  • 219 Answers
They are most likely a MOSFET type of transistor. If they are in the power supply part of the amp then you will probably need to replace all the MOSFET's in the power supply along with perhaps some gate control resistors for them. They each have their own resistors. It wouldn't hurt to see if the 494 IC in the power supply is working properly too. This IC is what sends the pulse width modulated square wave to the MOSFET's. Next you will want to test all the MOSFET's that are used as the audio output drivers and their predrivers and bias resistors. Don't forget to check the DC bias and offset on the outputs too, to make sure everything is OK there. In short, you will most likely need to go to a repair shop that can do all this and who would know what the heck I'm talking about. Good luck.
Posted on Mar 06, 2007
Brand new Audiobahn amp burning smell
i'd need more info but from what you've stated, sorry to break it to you but it sounds likely you've incorrectly wired you speakers and blown your amp. this will prove no doubt an expensive mistake and learning exercise.
May 23, 2017 | AudioBahn Car Audio & Video
Amp not working
I had a similar problem with a pyle amp. try to disconnect the speakers and turn it on if the protect light doesn't come on then you might have blown something in your amp and it needs to be repaired. For my situation it was a blown resistors and only 1 channel worked. If you don't have soldering experience then I wouldn't bother trying to fix yourself, an unsteady hand can ruin your repair.
Mar 26, 2010 | AudioBahn A8000T Car Audio Amplifier
All 3 fuses blown on amp worked fine for years
if all your fuses are blowing, you are crossing over or arching somewhere. Check you wires connecting to the amp and make sure everything is tight and that no loose strands are touching other wires around it. Hopefully the amp isn't just coroding out under the outer shell causing an internal short.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 08, 2009 | AudioBahn A2150HCT Car Audio Amplifier
I accidentlty made the positive and negative wires touch while connected to the amp what do i do
Check the unit for a blown fuse and replace it. Or reset the circuit breaker if it is equipped with one,
Oct 03, 2009 | AudioBahn A6004T Car Audio Amplifier
No sound protection light on.
Either blown subs, or bad amp.. Disconnect the subs, and try turning the amp on, if the amp is still in protect then your amp is bad, if the protect light goes off, then your subs are bad, or possibly wired at to low of an impedance, but I don't think that will trigger the protect on an Audiobahn amp.
Aug 21, 2009 | AudioBahn A2002T Car Audio Amplifier
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
Audiobahn A6601T amp. Protection light on. No Sound output.
Disconnect all speakers from the unit and then switch it on. If the protection light is still on then the output stage in the amplifier is blown.
May 12, 2009 | AudioBahn A6601T Car Audio Amplifier
Audiobahn A6004T
test for good 12v, ground and remote power to amp. make sure ur chassis ground is clean tight. if thats all good u have an internal problem
Jun 20, 2008 | Car Audio & Video
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A4004T Car Audio Amplifier Logo
466 people viewed this question
Top AudioBahn Car Audio & Video Experts
Mike Duncan
Mike Duncan
matthew walsh
Level 1 Expert
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
