Question about Hotpoint Washing Machines
Need to fit new pump on a hotpoint aquarius 1000 deluxe wm25
  • Hotpoint Master
  • 3,463 Answers
I assume you want to know how to fit pump.Remove the lower back panel, in the lower left hand corner you will see the pump, it has an inlet and outlet hose going to it.
Remove these two hoses and disconnect the 2-wire plug to the pump.
Tilt the m/c forward and remove the 2 screws securing the pump to the washer base
Remove punp.
Fit new pump in reverse order, very straight forward job.
Plz leave feedback.Thanks.
Posted on Dec 11, 2008
Hotpoint aquarius 1000 extra
have you checked belt or brushes in motor
Jan 26, 2012 | Hotpoint Washing Machines
Hotpoint aquarius 1000 (wma50p) not taking in water, and i cannot move the drum by hand.
Hello, it sounds like the main motor has blown. This causes the pump to stop as it is connected to the pulleys and gearbox. The only solution is replacing the main motor. Even though it sounds expensive, it should only cost around $100 plus fitting.
Mar 23, 2011 | Hotpoint WMA50 Front Load Washer
Noisey bearing on Hotpoint WM25 washing machine
Think the bearing is located in half drum in other words you need to fit half drum to fix/ parts about £55..+.2 hrs labour
Oct 31, 2009 | Washing Machines
Fitting pump to hotpoint WF250
disconnect the machine hoses and all drain put it on its side you will see the pump usually help in place by 2 screws/ 2 hose clips/ 2 wire thats it pump should cost no more than approx.18.00
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On my Hotpoint Aquarius WF000 1000 spin there are two lights flashing, one of them is the Time Delay ligh and the other is the Crease Reduction light, does anyone know why this might be occuring?
Try this out, it's for another hotpoint model:
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Would be good to check out the pump too
Mar 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius mwa42 will not empty
The pump itself should not be hot to touch, only warm, I would suggest a new one needs to be fitted.
Plz rate my solution.
Thanks.
Jan 16, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, my hotpoint aquarius wma42 washing machine washes ok but will not empty, i have took the filter out of the back and cleaned it, but its still doing it. can you advice
Make sure there is nothing stuck in the pump, and that the outlet hose is not blocked or kinked.
If o/k , then you need to confirm that the pump itself is working
Select drain only. or drain and spin, and you should be able to hear the pump running, if you are satisfied that there is no blockage any where and the pump is running, but no water comes out,
Then fit new pump
Thanks.
I am trying to fit a new drum belt on a hotpoint aquarius vtdoo reverse action
You need to remove the top cover, remove the right hand side panel,ease the drum forward and fit the new belt.
It is very difficult to fit the new belt without the proper tool avialable from Hotpoint.
It can be done without the tool, but be prepared to stuggle
Dec 04, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint aquarius 1000 deluxe W22 washing machine
the newer type motors have carbons tht are fixed in place you would need to remove the motor and on either side will be the carbons they need to be un-screwed to be replaced
Jan 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
74 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
