Error code E 6
I have an old Pitney Bowes Copier Model 9317
i receive and error code of E 6
however the manual does not list any error codes that start with E only tha start with U
  • wayne819 Dec 16, 2008
    I with a non profit enviromental organization.... it flashes E 6 than 01 if that helps..is there anyway i can fix myself? Because it is not in our budget to have a tech come in... and to take it to a proper recylcing plant it will cost 200 dollars as well
    President:
  • Office Equip... Master
  • 990 Answers
E6 have so many sub codes, but there indicated is duplex unit problem.
Posted on Dec 16, 2008
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Pitney bowes c 180 copier red wrench error
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
http://www.copytechnet.com/forums/panasonic/6754-panasonic-fp-7718-maint-counter-reset.html
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 31, 2010 | Pitney Bowes C180 Copier
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
Pitney bowes model c400 copier error 0070??
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
Aug 19, 2009 | Pitney Bowes Office Equipment & Supplies
New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Aug 26, 2008 | Pitney Bowes C180 Copier
305 people viewed this question
jasbo
jasbo
