Question about Kenmore Dryers
Dryer keeps burning out thermal fuse and thermostats
My dryer recently quit working, so I brought out the repair manual and started troubleshooting. I found that the thermal fuse and one of the operating thermostats had gone bad. I replaced them both and it worked for about a day. I have retested the and the same parts are bad again. Could it be something wrong with the heating elements?
  • jlharrell Dec 11, 2008
    All connections are tight. Appreciate the reply. Any other suggestions or paths I should try?
  • 417 Answers
If the thermal fuse and thermostat are bad,something is causing them to overhea,t before tackling the heating element, you should check all connections to the stat and fuse as a loose connexion could be the cause of the over heating.
Posted on Dec 11, 2008
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
If the lightbulb burns out in a whirlpool duet gew9250pw1 dryer will that cause it to quit working
Generally, a burnt-out bulb will not stop the dryer from working. However, the bulb may have failed due to a power surge. In that case, you'll have to check the components that could have also been damaged.
First, check that the circuit breakers are on. (There may be two breakers for an electric dryer.) Next, is the drum turning or does the unit not start. If the control board buttons aren't responding, the electronic control is likely bad or the wiring harness has an issue. If you aren't getting heat, you need to check the thermal fuse (thermal cut-offs), wiring, thermostat (high temp limit) and element. A multi-meter will tell you if the fuses have the appropriate resistance (10-30 Ohms).
I hope this helps.
(note: if you recently had a nearby lightning strike and other electric appliances were damaged, check if your insurance will cover the costs of repair after you meet your deductible.)
Jun 07, 2013 | Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Sensor light comes on when you push the start button but does not start spinning
This is a problem commonly caused by a blown thermal fuse due to a faulty thermistor or cycling thermostat depending on the model of the dryer. The thermal fuse is located on the blower housing and wired in series with the motor. The motor cannot therefore run when the thermal fuse blows open and no dryer functions works.
Unplug the dryer then remove the bottom panel and the lint duct and check continuity of the thermal fuse. You can also bypass the thermal fuse for troubleshooting purposes. Check for blocked lint filter and restricted vent system if the thermal fuse is indeed blown then replace it including the thermistor/cycling thermostat. Click on the link below for detailed troubleshooting of this common problem.
Kenmore Elite and Whirlpool Duet Dryers Not Starting
Jul 19, 2011 | Whirlpool GEW9250 Electric Dryer
Wont start, is there a fuse? and where is it
There's a thermal fuse located on the blower housing along with the cycling thermostat and is wired in series with the motor. This thermal fuse blows when the lint duct and vent are blocked or when the cycling thermostat is stuck closed or not cycling properly. Power to the motor is terminated and the dryer will not start once the thermal fuse blows and no dryer function works. Make sure the lint duct and vent are clear. Click on the link below for the detailed troubleshooting instructions but make sure first that the dryer is getting power.
Troubleshooting Whirlpool and Kenmore Dryers
Not Starting
Mar 09, 2011 | Whirlpool LER5636P Electric Dryer
Push to start switch seems like it lost its spring effect- could that be the problem for a no start- model len2000kq1
The push-to-start switch rarely causes the dryer not to start. It doesn't necessarily mean that the PTS is out if the dryer doesn't start. What usually causes this problem is the thermal fuse blown. The thermal fuse, located on the blower housing along with the cycling thermostat, is wired in series with the dryer motor. Power to the motor is then terminated and it cannot run when the thermal fuse blows either due to a restricted duct or malfunctioning thermostat. Make sure the vents and ducts are clear. Click on the link below for the detailed troubleshooting and repair. The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers with Lint Filter on Top
Feb 22, 2011 | Whirlpool Dryers
Dryer will not start
The temperature of the air being exhausted is monitored by the cycling thermostat and the thermal fuse mounted on the blower housing. The thermal fuse, which is wired in series with the motor circuit, fails when the cycling thermostat fails to regulate the exhaust air temperature. Failure of the thermal fuse results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
Indicate the exact model number of the dryer for specific troubleshooting and repair advice if you need further assistance and for the exact part numbers.
May 27, 2010 | Whirlpool LER4634J Electric Dryer
The dryer will not start but the timer is working
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
May 21, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Dryer turns but doesn't heat. How do I troubleshoot?
Likely causes are:
- broken heating element
- burned/corroded connections in heating circuit
- blown thermal fuse / limit switch
- bad thermostat
If you don't have significant of experience with electrical appliance troubleshooting & reapir, this is a difficult task.
May 08, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Dryers Logo
579 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
