Question about Haier BC112G Wine Cooler
"EE" is flashing & beeping continuously in the temperature window. I have pushed all of the temperature buttons but the temperature won't reappear. Just the flashing and beeping "EE".
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
How to Get GE Oven to Stop Beeping eHow
Apr 21, 2014 | Whirlpool Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
Oven won't start
Try pushing the "convection oven" or "bake" button first, then enter the temperature you want. Then "Start".
Sep 24, 2012 | Thermador SC272T Electric Double Oven
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
When I plug it in the screen shows EEE, and beeps continually. It is around 65 degrees in the area. Nothing clears it or stops the beeping. It worked great yesterday.
The error code E:EE means the breadmaker thinks the temperature is too cool i.e below 59 degrees F or 15 degrees Celsius.
As you say the temperature is actually 65 degrees - then this means that the temperature sensor on the Bread maker has failed and will need to be replaced.
The EEE code and beeping will continue until the failed sensor is replaced and as this is a component failure it cannot be reset unfortunately.
Thanks for using FixYa.
Sep 11, 2011 | Regal Ware K6725 Kitchen Pro Bread Maker
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
Hi, I have a Bosch undercounter freezer and it won't stop beeping!!! All the lights flash whilst beeping, the lights are under the super freeze button, mute button and the temperatures. If I hold...
The beeping is a signal that the fridge has not got down to, or holding temperature... You may have a thermostat or gas system fault. Check and see that the fridge has actually got cold.
Jul 31, 2011 | 2007 Harley Davidson FLHX Street Glide
JennAir 27
try unplugging the range for 30 seconds and see if it resets
Apr 01, 2008 | Ovens
Haier BC112G Wine Cooler Logo
89 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
