Question about Kenmore 12912
I was trying to sew through some very heavy material, and my needle got stuck. Now, when I try to sew, the bobbin thread will not feed properly and just gets bunched up under the plate.
  • 96 Answers
Change the needle to a proper size for heavy fabric and heavy thread appropriate to the needle a number 14 or 16 needle
Posted on Dec 13, 2009
Singer 99 not feeding heavy thread.
Unfortunately, your domestic machine was not made to sew leather. It can probably sew lighter weight leather with a lighter weight thread. Your thread is most likely too heavy for the machine you are using so it is not able to pick it up properly.
Apr 19, 2017 | Singer Sewing Machines
How do I raise the feed dogs
Make sure that your top and bobbin thread are the same and that the tension is set correctly. Then, be sure that the bobbin is put in correctly. If this happens when you are starting on an edge of your material, try putting a piece of material or even a piece of paper, like typing paper, under the edge of the material and sew a little beyond that and then onto your material. You can tear it off later. It gives stability to the edge of the material and should alleviate the problem. I hate when that happens! And, last but not least, be sure you are using the right needle. I love the ballpoint needles for most sewing projects.
Dec 30, 2015 | Baby Lock Evolve
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
When I put the pedal down, the bobbin jams, and cuts the thread
try changing the needle
make sure the needle & thread & fabric are correct for each other
make sure ever thread guide is being used
try adjusting the top tension
Apr 01, 2012 | Sewing Machines
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
My material gets stuck in
check and see if the feed dogs are above the needle plate when the needle is in the upright position, then check and see if you have tension in the upper and lower tension units, check this by putting the foot down and gently pulling on the upper thread and pull the lower thread up through the plate and see if it pulls easy or hard if hard then it is good one last thing are the feed dogs in the raised position
Oct 17, 2009 | Sewing Machines
Can the consew 339rb-1 be used only with 1 needle?
this is the specifications for the 339rb-3. they sould be close to yours, if you can put two seperate needles in and the machine hase one hook and bobbin case then I would say you can use one needle, if you have two hooks and bobbins, I would say no, you may want to thread with one and just hand turn for a few stiches to sew hoe it reacts, leave the bobbin door open so you can watch the hook.
  • Two needle mechanism readily makes two parallel lines of stitches
  • Compound feed, walking foot mechanism insures even feeding of material
  • Large hooks and bobbins assures longer operation between bobbin changes
  • Centra-Lube® semi-automatic lubrication system
  • Automatic hook lubrication
  • Oil fed take-up
  • Simple adjustment permits raising and lowering of the center foot which allows for sewing different thickness of material
  • Safety clutch protects the hooks from being damaged
  • Various needle gauges available
  • For sewing light to heavy-weight materials such as leather, vinyl, upholstery, synthetics, canvas, vinyl and various coated and laminated products
  • Designed for stitching such products as auto, boat and furniture upholstery, tarpaulins, covers, sails, tents, camping trailer covers, awnings, umbrellas, tops, bags, luggage, handbags, travel ware accessories, sports and camping equipment, wearing apparel, outdoor clothing, canvas shoes, slippers, orthopedic appliances, etc.
  • Suitable for double needle seaming, binding, taping and piping operations
Aug 27, 2009 | Consew 339RB-3 Sewing Machine
Bobbin area will not work
There should be a spinning cover with a hook that fits over the bobbin. Normally, you just pull the bobbin thread out through the swinging/sliding plate hole. Turn the machine by hand toward you (at the top) until the needle dives into and comes back with both threads. Separate the threads and assuming that the thread tension above the needle is set correctly, feed a piece of material in to see if it sews correctly. The tension is set so that the thread is even on both sides of the material. Let the machine pull the material through at it's own pace, your function is to guide the material.
Jul 17, 2009 | White Sewing White 3032
Time janome 3018?
when you say 'bobbin thread bunches' i take it that when you look at the underside of what you have sewn it looks messy. if this is the case and the machine is threaded correctly and the the needle thread is tight enough to bend the needle a little when pulled (with presser foot down) it will most likely be that you need to increase needle tension (maybe to max) when sewing thick fabrics with thicker than normal thread.
if the the needle does not bend a little you may not have the thread in between the tension discs, or there may be thread or lint caught in the tension discs preventing proper tension (try pulling a thin rag through the tension discs to dis-lodge any foreign matter).
Jul 17, 2009 | Brother PE-150V Computerized Sewing...
Sewing Machines Logo
111 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
