Question about Acer Aspire 3680 Laptop
Computer stoped working
I have an aspire 3680 laptop and it stoped working. the battery is great and the ac adapter is good too but when i try to turn it on the ac adapter light flashes and then it dies
    Problem Solver:
  • 8 Answers
If you're certain that the battery is fully charged, then there could be an issue with your hard drive, or possibly motherboard.
Has the laptop ever been wet, or outdoors overnight?
See if you can boot from your disk drive by inserting your operating system disk in the drive when you turn it on.
Also double check that the outlet you're using is actually supplying power, I have bad outlets in some parts of my house where my laptop won't charge up.
Hope that helps, keep me posted
Posted on Dec 12, 2008
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610, LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ... > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
No power. Adapter light flashes when connected to laptop
thanks for using fixya!!
Please do and observe the following:
1. Uninstall the battery pack.
2. Then, connect the AC adapter, we will try to use the power coming from the AC, then turn on your laptop.
3. Observe what will happen.
4. If still doesn't work, install again the battery, then connect the AC adapter, check if its going to work.
5. If not, perhaps you have a problem neither with the battery or the AC adapter.
I suggest that you bring your laptop to a service center. Good luck!
pls rate me positively! thanks!
Mar 30, 2009 | Acer Aspire 3680 Laptop
Laptop stoped
there is a short circuit in the laptop inside.
Dec 09, 2008 | Acer Aspire 3680 Laptop
Laptop stoped working
I have an Aspre 3680 as well, and a flashing adapter light is not a good sign, I suggest you get a multi meter and test for to make sure you are getting the 19 volts output that are required to run the laptop and charge the battery.
My goal is to provide you with a helpful fix ya solution, if you found this advice helpful please rate it as Fixya, thanks
Running slow Aspire 3680-2682
in your case it could be your battery is bad.
battery can cause alot of strange thing.
from slow to touchpad/keyboard not working.
But most of the slow problem it cause by
1. memory.
Make sure you have enough memory
2. software.
Tried to re-install the operating system.
3. defective harddrive.
May 04, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 2682 will not power up
there are some reasons laptop can't power on, try to troubleshoot.
1. Make sure that your ac adapter is working. if you plug battery and ac adapter, the battery chargin led will be orange and if the battery is full, the led will be yellow.
2. Can you power on using battery ? if you can and you can't power on using ac adapter (i assume your ac adapter is working). the problem will be your power port.
if you can't power on using battery and your battery is working ok. the problem will be motherboard.
Apr 18, 2008 | Acer Aspire 3680 Laptop
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Nov 11, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
