Question about Goodman GMS90703BXA Heater
Induction Motor continues to run.
I am blessed to have a GMP125-4. A few months ago I replaced the induction motor. The furnace has been working fine up untill 2 days ago. When the unit begins its cycle, the induction blowwer kicks on and then nothing happens. It continues to run for ever. The HSI never turns on. If however, I kill the power to the unit then turn it on. It works fine untill it calls for heat again. I'm thinking its the circut board any other suggestions?
  • harrison191 Dec 12, 2008
    Well no one responded but just in case anyone else has this problem..I fixed it by replacing the board. Not that difficult. Take a few pictures of the set up and lable everything before you remove it.
  • Anonymous Mar 01, 2009
    I have the exact same problem.
  • Goodman Master
  • 5,568 Answers
I'm sure you have since had this repaired and as a fellow Goodman 'blessed' I would appreciate reading your solution.
The condition you described could be caused by a failed relay or relay driver (transistor). Fortunately, the only problem we have had to date (~4 years) is a failed thermostat and a need for recharging of the AC coolant this last summer.
Posted on Sep 28, 2009
    Sergeant:
    Champion:
  • 232 Answers
Pull the rubber hose off the pressure switch. and blow into the Induced draft motor housing if you cant you can pull the hose off the IDM and try to clear it with a small paper clip. reconnect and try again. you can also get the flash code off the board while the unit is running but not working.
Posted on Sep 18, 2009
1991 Miller/Nordyne cmf-80 furnace Periodic non ignition
That's a "mind of its own" condition that I've gained & lost customers over. When the unit first starts in heat, you mentioned the induced draft motor will start with no other reaction from the system, that should be the best time to locate the issue by using a volt meter. If you are getting 24 volts to MV/PV at the gas valve then you know all of the heating circuit has "proved", and that the gas valve is the problem. If not, the backtrac until you find 24v. Now if you are simply just changing parts until you find the problem, which we've all done, I believe you've changed all that you can. Check all wire connections. Its probably a loose, corroded, or damaged wire/cannon plug(the plastic plugs that multiple wires are connected), stopped up gas pilot orifice, or the gas valve its self. Hope this helps!
Feb 15, 2017 | Heating & Cooling
My rheem gas furnace got red button that keeps griping what can I do.
The red button that keeps tripping is probably the rollout sensor just above the burner assembly. When this rollout starts tripping, it means your flue gasses are not being drawn out by the induction fan motor. If your furnace is a few years old, the fan blade has probably rusted out and is not moving the flue gas. You will need to get a new induction fan motor. While you are checking the induction fan motor, it is a good idea with everything torn apart to check the condition of your heat exchanger. When the induction fan blade rusts out, it is a good indicator the heat exchanger may need replacing also. So do yourself and favor and check it out for rusted out welds and the like. You will probably need an experienced hvac tech to make the furnace repair.
Hope this helps.
Dec 31, 2014 | Heating & Cooling
Inducer Motor Noise
Bad induction assembly is common with these units. If it's the style that has the motor install in what looks like a square black plastic box with tube connections off to the left and right. Replace the whole assembly, not just the motor. If you are mechanically inclined replacement isn't to hard.(make sure electricity to furnace is off). Cost to purchase induction assembly(look online) is around $300. If you have a company do it expect a bill between 650 and 800.
Mar 14, 2014 | Bryant 352AAV036060 352AAV 60,000 BTU, 92%...
My heil n9mp2 isnt working just hums
is the flame igniting and then cutting off? on a gas furnace, the induction fan motor(draft motor) should start first (if the furnace is so equipped), then the flame, then the blower. if you have an induction motor (flue gas exhaust mmotor) this may be your problem (the induction motor isn't starting), if your unit doesn't have one, have you checked to see that you have gas? finally, the capacitor on the blower motor may be causing the motor not to start.
Jan 06, 2013 | Heating & Cooling
I have a York Stellar Plus furnace (1994 model) on which the ventor (air induction) motor will not turn off. This problem just started. The Furnace seems to work fine, but the ventor runs continuously. I'm...
The W on the board initiates the start up sequence so I believe your problem is with the relay on the control board. probably stuck closed you need to replace the board
Apr 12, 2011 | Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
Induction motor won't shut off. Red light flashes 5 times.
This just means it is throwing a code which can usually be found on the back of the furnace door covers. With the induction motor staying on, that usually means that you have tripped a limit switch. Some limits can be reset by pushing a button or cutting power to the unit and letting it reset that way, just depends on your model of furnace. Also some basic things to look for, make sure your return is not blocked or your flue is not blocked. And sometimes, your induction motor will have a little hose that runs to a limit switch, and if you take a small piece of wire and try to unclog the small hole on the induction motor housing, it could also work. You can also check your limit switch that the hose runs to by putting your lips on the hose that you just pulled off the housing and **** in and blow out, you should hear it clicking inside. Another limit you may find, is one sticking inside the cover of the heat exchanger inside the furnace, often you can simply take the two screws out, pull the limit out, gently rub it off just in case its dirty, reassemble it and it works. These of course are all things that may help, but there is no telling how long before it happens again. Some have worked years, others just days. If this did not help in your case, a model number and possibly the code it is showing would be greatly helpful. Good luck!
Mar 22, 2010 | Heating & Cooling
I HAVE A YORK STELLAR PLUS,MODEL PEUDD12N09501C 15 YEARS OLD. THE AIR INDUCTION MOTOR RUNS FOREVER. THE AIR INDUCTION MOTOR COMES ON , THE THE THERMOSTAT CALLS FOR GAS, THE IGNITOR LIGHTS THE GAS, FURNACE...
Check the filters first, then check for blockage in the return or supplies. An easy way to do this is by putting your hand in front of the vents to make sure accurate airflow is there. Your furnace has limit switches on it that detect heat, and if heat is getting trapped inside the unit to much, you will trip these switches and the blower will just run forever. Then you have to reset it or wait forever. But try those few things first. Hope this helps.
Nov 26, 2009 | York Yankees Bedding MLB Comforter
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
222 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
