Printer shows out of paper.Can't remove this so printer can print.Put in paper and this doesn't remove this statement
Unplug power and USB Removed all printing from printers and fax right click.restart computer .this worked
Posted on Dec 12, 2008
I`m using HP Photosmart C3100 Series. The problem with my printer is that it doesn`t print the whole page, only half of the document was printed and then it will ask you to load another paper then it...
This sounds like the printer driver has become corrupted. Try unplugging the printer, and removing the drivers (from Add/Remove programs in control panel (XP) or Programs and Settings (Win7)).
Once the driver is removed, reboot the computer, and put the original driver disk back in the computer, and plug the printer in when prompted by the HP software.
Jul 23, 2011 | HP Office Equipment & Supplies
Hi, my calculator casio hr 8tec shows the message " e P" and it's doesn't print anything. It`s like it's stuck.... Thanks
It thinks it's out of paper.
Pull out and re-feed the paper.
If it's out of paper, put more in.
If that doesn't help, remove the paper, and take a look at the paper out sensor, and make sure it's functioning ok, and re-insert the paper.
Jun 27, 2011 | Office Equipment & Supplies
After replacing the cartridges, it doesn't print. Is there a problem with the head as the printer was not used for a long while
After installing new catridges, try to goto the printer options. in the serives option do the ALIGN THE CATRIDGES. then it will aligh the catridges correctly and it may print.
This procedure works for some models of printers.
Jun 14, 2011 | Office Equipment & Supplies
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
New Ink does not show up on Paper!
Did you remove the plastic film off the cartridge before you put it into the printer?
Apr 20, 2010 | Dell A960 All-In-One InkJet Printer
Can't figure out how to print on statement sized paper.
After I had been attempting to adjust the paper guides in the feeder tray to accommodate statement-size paper, I finally "discovered" the drop-down door to the manual feed tray.  Duh!  This is a networked printer that I've only ever used for printing letter and legal sized documents until now.
May 28, 2009 | Lexmark T640 Laser Printer
HP Officejet All-in-One Printer
remove all the wires connected to the printer from its back.also wait for 5 minutes.then delete any pending printouts in the printque of the printer in your pc.shut down the pc.connect the printer to the pc.ON the printer.then ON the pc and then try printing it should work.
thanks.
Nov 15, 2008 | HP Hewlett Packard LaserJet 3000dn Printer
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
74 people viewed this question
k24674
