Question about Akai PT4298HD Rear Projection Television
I have a AKAI Model PTH5498 HDTV that worked great and had great picture and sound until it was turned on for 20 minuets and then it shut off. If you unplug the tv and then plug it back in you can hear something insude of the tv click 3 to 8 times and then the on light in the front control panel stays on. My PTH5498 worked one day and then not the next, it will not turn on manually or with the remote. I unplugged it and then plugged it back in and now the red LED light on the front at Timer is lite but it still won't turn on. What can I do to resolve this?
  • 121 Answers
Safty shut down. b+ or hv circuit prob. need tech.
Posted on Dec 11, 2008
    President:
  • 2,110 Answers
Your EHT needs to be replaced...so try to take it to nearest service center...
  • 10,594 Answers
It can be power supply problem or some thing wrong in deflection area.
You need to have service manual to check above areas in TV.
Let me know if you need further info.
  • 734 Answers
There is a problem in the dc adapter of your tv,, the adapter is inside the tv.Thanks
AKAI model PTH5498 turned it on in morning and it worked fine, then went to kitchen then heard a pop then a buzzing noise tv had no picture
Short on the power and deflection boards---with set unplugged take a careful look inside for burnt or blackened parts etc.
May 17, 2012 | Akai PTH5498 54" Rear Projection...
My Akai PTH5498 54 in. Rear Projection hdtv-ready Television power shuts off intermittently. Sometime after only a few minutes sometimes after an hour or so.
There could be number of problems but most likely its the horizontal chip that is heating up and failing. If you are a tech feel the chip after the set shuts of it's normal for it to get hot but not extremly hot. If it is extremly hot it is your problem.
Jun 21, 2010 | Akai PTH5498 54" Rear Projection...
Akai 54' projection tv picture no sound
U obviously don't have all ur sund cables connected right or if ur running it through ur sound system put it on phono
Mar 05, 2009 | Akai PTH5498 54" Rear Projection...
Double image
If your model number is the PTH5498 you will need to replace both convergence ICs they are stk 392-040 you can get replacements at the followig link and they will provide fre instalation instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Jul 11, 2008 | Akai PTH5498 54" Rear Projection...
Akaia PTH5498
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
http://www.partstore.com/GetModel.aspx?MfgName=Toshiba&BrandName=Toshiba&ModelNu...
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 27, 2007 | Akai PTH5498 54" Rear Projection...
AKAI 1080i HDTV 42"
Aug 27, 2007 | Akai PTH5498 54" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
153 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
