Question about Canon imageRUNNER 210S Copier
Can't fine servers during LDAP search
During send email, cannon can't search LDAP servers. It says can't find servers. We can ping cannon' s IP adress from domain controller but somehow t cann't seach users in LDAP servers.
cannon image runner
C28801
  • 76 Answers
Hi
try to change the setting of lancard speed to half duplex of photo copy machine
Posted on Dec 11, 2008
HP 1312 printer running wirelessly from a laptop (Windows 7). Has always worked fine. Turned printer off when we were on vacation; now printer is "offline." Have reinstalled printer driver and...
Hi!
The problem you described can have multiple causes.
But one is more common:
Every device on your home network (wired or wireless) has its own IP adress. Usualy this IP adress is given automatically by the DHCP server contained in your wireless router. When a device is turned off for some time, it can receive when turned on again another IP adress than before.
So, if your printer has no static IP adress (entered by yourself during printer setup), it is very likely that it has now other IP than the address known by your computer. The computer sends the print jobs to the old adress and of course, nothing is printed.
Please check in your printers proprieties the adress of the TCPIP port assigned tom it, and also check on your router's management site what clients are connected to it.
The network communication between the computer and the printer can be checked by issuing a PING command from a command prompt.
e.g ping 192.168.1.***
the numbers are one example of an IP adress.
Please let me know if it helped, if you need more help ask again, I'll be glad to help you to get the problem solved.
Regards,
Bogdan
Aug 21, 2011 | Office Equipment & Supplies
I'm forget admin password on hp 9250c. Please, how recovery admin password.
Cold reset for HP9250C
A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
Embedded Jetdirect IP address
SMTP IP address
LDAP IP address
Embedded Web server password
All control-panel configurable items
The following items are NOT cleared during a cold reset:
Local address book e-mail addresses
Real-time clock (date and time)
Page counts and maintenance counts
Product serial number and formatter number
Service ID
Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Oct 04, 2010 | HP 9250c Printer
How do i reset the entire system back to default? Previously someone had put an admin lock on it so now i cant use it properly and i need to reset the menus.
Hi
· It is called the Cold reset
A cold reset resets the values of permanent storage variables back to factory default. Often this is
necessary for clearing the HP MFP Digital Sending Server IP address.
● Embedded Jetdirect IP address
● SMTP IP address
● LDAP IP address
● Embedded Web server password
● All control-panel configurable items
● Local address book e-mail addresses
● Real-time clock (date and time)
● Page counts and maintenance counts
● Product serial number and formatter number
● Service ID
● Event log
3. While the product is performing its memory count, hold down the #6 key. When the three status
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | HP Digital Sender 9250c scanner Printer
LDAP issues with Konica C451
5 Network settings
5-52 bizhub C650/C550/C451 (FE3)
Setting up LDAP
Register LDAP servers and specify authentication settings. Settings can be specified for the following.
Setup LDAP screen 1/6
Setup LDAP screen 2/6
Setup LDAP screen 3/6
Setup LDAP screen 4/6
Parameter Description
LDAP Server Name Type in the name of the LDAP server to be registered.
Use the keyboard that appeared in the touch panel to type in the server name (32
characters or less).
Max. Search Results Specify the maximum number of destinations to be displayed after a search. To
change the setting, press the [C] (clear) key, and then use the keypad to type in
the desired setting. (Range: 5 to 1000)
Timeout Specify the maximum wait time for a search operation. To change the setting,
press the [C] (clear) key, and then use the keypad to type in the desired setting.
(Range: 5 to 300 seconds)
Initial Setting for Search Details Specify the initial search conditions for "Name", "E-Mail", "Fax Number", "Last
Name", "First Name", "City", "Company Name" and "Department" in an advanced
search.
Server Address Specify the address of the LDAP server. Use the keyboard that appears in the
touch panel to type in the address (255 characters or less).
Search Base Specify the search starting point in a hierarchical structure arranged on the LDAP
server. Searches are performed by also including the sub-directories lower than
the starting point that was specified.
Use the keyboard that appears in the touch panel to type in the address (up to 255
characters).
SSL Setting Select whether or not SSL (data encryption) is used when connecting to an LDAP
server.
When SSL is used, communication information is encrypted.
Port Number Specify the port number for the LDAP server. To change the setting, press the [C]
(clear) key, and then use the keypad to type in the desired port number. (Range: 1
to 65535)
Port Number (SSL) Specify the port number when SSL is used. To change the setting, press the [C]
to 65535)
Authentication Type Select the authentication method used for logging on to the LDAP server.
Anonymous: This authentication method does not require a user name and password.
If "Anonymous" is selected, dynamic authentication is disabled.
Simple: This simple authentication method requires a user name and password.
Be careful since the passwords can be leaked over the network.
Digest-MD5: This authentication method can be used on a typical LDAP server. If
authentication fails using Digest- MD5, the authentication is performed by automatically
switching to CRAM-MD5.
GSS-SPNEGO: This authentication method can be used with Active Directory in
Windows (Kerberos authentication).
NTLM v1 and NTLM v2: These standard user authentication methods can be used
with Windows NT.
They can be used for logging on when sharing files and printers.
bizhub C650/C550/C451 (FE3) 5-53
Aug 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can get LDAP search working on BizHub 350 Multi function copier
the smtp serwer wos chench u nead to setup scan for email whit new seting of smtp
Jul 31, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
LDAP lookup fails on Xerox WCP4150
I would check your software version. Several of the older versions had a lot of LDAP problems.
You can print out a system report and find your Firmware level, then go to Xerox.com, go to Drivers and Downloads and see what the new version. Current firmware level is 10.100.46.000 . follow the instructions.
May 11, 2009 | Xerox WorkCentre M15i Laser Printer
Trying to Email documents from RICOH
start by checking authentication... make sure your smtp server login is correct, also change your smtp name to ip format... run cmd and ping your mail server... example ping mail.server.com it will respond its ip address
May 07, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 192.168.42.24 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping 192.168.42.24 On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
Canon imageRUNNER 210S Copier Logo
405 people viewed this question
old marine
old marine
