Question about Canon EOS-AE-1 35mm SLR Camera
Film wound on wrong side of camera
Have a canon t50 35 mm camera-am new at using it and wound the film the wrong way when finished taking pictures. now film is over on right side of camera instead of left and can't get it out of the camera.
  • 148 Answers
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Posted on Dec 11, 2008
    Scholar:
  • 185 Answers
Kelly-maxwel,
your T50 advances the film automatically to the take up spool but the film must be manually rewound .
push in the rewind button and turn the rewind knob right until the film is fully in the canister.
A clip came off my Cannon sure shot 150u on the left side and it wont wind the film, how do i fix?
hi, this is film camera uses 35mm film , the clip is used to keep the film wound tightly on the take spool, no problem , use ultra thin cello tape on the tip of the film and attach it to the take up spool , ensure that the rewinding stops as soon as the counter reaches 0 or 1 , in case the camera does not have switch, remove the battery on time hope this works
Aug 31, 2016 | Canon Cameras
Canon prima super 115 film type camera which type batery use
It takes one 3V lithium battery, CR123A or DL123A or equivalent.
If you need a manual, you may download a copy at http://www.cameramanuals.org/canon_pdf/canon_sureshot_prima_105_zoom-1.pdf
Apr 20, 2012 | Canon Prima Super 105X - Point & Shoot /...
Do i need to rewind film after taking a picture on my diana f+ ??
If you are using 120 film (medium format) you only need to advance the film as far as possible. Then remove the film from the camera and wrap the excess paper around the roll and seal.
When you finish all the pictures on the roll of 35mm film you will need to rewind the film completely before exposing it to light. You can do this by taking the camera in a pitch dark room, removing the film and turning the knob on the top of the film roll until the film has been completely wound back into the the roll.
Mar 29, 2011 | Lomo Diana F+ 35mm Film Camera
I accidentally pushed the film release button before finishing my film, and it won't pop back out. it won't let me take pictures too. how do you fix this?
The mechanism won't re-engage until you open the door (camera back) and shut it again, then wind on and fire a few shots as if starting a new film. You could open and shut the door in total darkness, and then waste a few shots to carry on with the film in the camera, but the frame counter will be wrong. Unless there is a lot of film left on the cassette, you might as well just rewind it and start again with a new film. Yes, you will probably be paying more than you should for the processing and printing of a partial film, but you will get your pics.
Jan 09, 2011 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
My Canon AT-1 35mm does not take pictures
Remove the bottom plate.
There is a long lever that attached to the wind gear. On the opposite end, it has electro-magnet. You will need to replace this magnet.
Apr 23, 2010 | Canon AT-1 35mm Film Camera
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Feb 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
I may have loaded film roll that has already been taken?
Usually when you finish exposing a roll of film, you rewind it until you are sure it is all wound into the cassette. There is a change in the sound as the end of the roll leaves the camera. An exposed roll would have no film sticking out of the cassette. A new unexposed roll will have a bit of film sticking out of the cassette to pull across the ack to the take up roll.
May 26, 2009 | Canon Elph LT APS Point and Shoot Camera
How do you open te Vivtar V4000?
I have used left/right as if you are holding the camera ready to take pictures.
I have included the instructions to rewind the finished film.
!/ Press and hold the film rewind button button on the right side of the camera base.
2/ Fold out the rewind crank top left of camera and turn it in the direction of the arrow.
3/ Once the pressure eases, the film is completely wound into the cassette.
4/ Lift up the film rewind knob top left of camera and pull it out to open the back cover. Now the film cassette can be taken out.
5/ Do this in a place away from direct sunlight.
Jan 05, 2009 | Vivitar V4000 50MM 35mm SLR Camera
Canon A1- Just stopped working
Get a dummy film and put it in the camera , make shure that the film is fully loaded on to the take up spool and test it all the way through, It sounds like the film is coming off the take up spool. I have repaired a lot of these A1's and they don't suffer from this problem. yours Tim 01689 818009..
Oct 03, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
259 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
