Question about HP W22 LCD Monitor
Screen image appears fuzzy, jumpy and broken up into lines.
HP w22 LCD monitor and HP Media Center m8020n. I've had this system for a year and this is the first time this issue has occured.
When starting up the computer, the screen image immediately appears as hazy, distorted and jumpy, and it flickers rapidly with obvious 'pixilated' lines breaking down across the breadth of the image.
If, after I go to a few applications for a couple of minutes such as email, pictures, or anything else, the problem suddenly rectifies itself and the screen appears normal. This occurs everytime I now start it up.
The monitor says it is functioning properly. The cables are tight. There are no new updates for NVIDIA that I've downloaded. I have only 6.69 GB of 290 GB free on the "C" drive. I don't do gaming or watch TV or many videos.
  • 1 more comment
  • nilus Jan 05, 2009
    same issue. The Picture is very bad and it got worse now. I tried 2 different computer one with VGA and one with DVI. Same thing. I GUESS it is trash now.
  • billyadams83 Jan 19, 2009
    My screen is only 2 weeks old and doing the same thing.....trash!
  • Anonymous Apr 11, 2009
    Same problem , and also with two weeks monitor started flicking and now it changes the brigthness and contrast himself
  • 732 Answers
Gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Posted on Nov 02, 2009
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
My Neovo E-W22 monitor quit working. I have had it just under 2 years. It is as if it is getting no power. Any ideas?
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 09, 2010 | Neovo AG H-W22 TFT - H-W22 22 inch LCD...
Odd red fuzzy screen on desktop
Hardware failure in either the video chip or the lcd panel itself. To check which connect the laptop to an external monitor and see what appears: if the lines are still there then it's the chip - unreplaceable, the entire laptop is good for the skip; if the image is crystal clear then the panel must be replaced. If the laptop is still in warranty send it to them.
Jan 09, 2010 | HP Compaq nx7400 Notebook
HP w22 Monitor display disappears after about 2
bill, if monitor not covered by warranty, the check out YOUTUBE for long 8-12 minute video clips of LCD monitor disassembly or LCD monitor repair to find out what the major cause of your monitors SYMPTOM that you described above. Here is a small hint for you. If you didn't see the displayed data on the BLACK lcd panel with the flashlight "trick" then you would know that the entire "switch-mode-power-supply" was in complete SHUTDOWN mode or even blown the "line-in fuse" for the monitor. Also try a visit to www. ccl-la.com/badcaps.htm and view some of their vids on repair of lcd SMPS/INVERTER supplys and cold-cathode-fluorescent-lamp replacement. They also do the repairs and return shipping. Please rate this on fixya if this response was helpful. Bye for now. 12fixlouie
Oct 25, 2009 | HP W22 LCD Monitor
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Line of Laptop Displap
You could have a faulty LCD screen or a faulty video cable/connector.
Try reseating the video cable/connector that connects to the motherboard. If this doesn't work a replacement LCD screen may be required.
Check LCD Parts for parts and repair service, Use this link.
www.lcdparts.net
Jun 20, 2009 | HP Computers & Internet
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
Computer screen goes black
Update the BIOS of your Computer it will resolve the Issue.
Jul 13, 2008 | HP Media Center m7250n (ED842AA) PC...
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP W22 LCD Monitor Logo
1,006 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
