Question about Dishwashers
Frigidaire hot water problem
Is it possible that a melted plastic spatula on the heating element inside the dishwasher caused my water heating problem? How do I test it? Is it replaceable?
  • mietusjm Jan 09, 2009
    Professional series PLD 2850 RDC1
  • 409 Answers
No, i don't think so. the heating element is located under the inside tub and out of the dish area. if you could supply me with the make and model #, I will try and find the exploded view for you. the element is replaceable.
Posted on Dec 12, 2008
My ice maker is making ice, but it won't come out of the door. It gets stuck outside of the icemaker in the door. There is a flap that doesn't seem to be opening.
The units I have seen which have a flap, if water gets in from some drippage, it can freeze and make things get stuck. You might try some hot water on a small towel against the outside of the flap to see if that would melt any ice accumulation, or if you put a small pan under the flap hole on the outside to catch runoff and dribble a bit of hot water from the inside hole down spout to melt any ice that might free it up if that is causing it to stick.
You also might be able to fish out the ice from the inside and give flap a push to open it, or use a plastic spoon or spatula to push it through. While you might be tempted to melt the ice with a hair dryer, don't do that. It could be very dangerous if water suddenly spewed out and got into the heating element or motor and cause a fire or electric shock. Stick to not water and plastic to try and push it from the inside outward. Usually the mechanism to grind the ice is up above inside the freezer, not in the hole in the door.
If the door got stuck because its hinges came loose broke you might have to call a service center to come and replace it if you are unable to yourself.
Be careful and don't try anything if you are unsure of yourself.
Jun 17, 2015 | Samsung RSG257AARS (241 cu ft) Side by...
Can calcium deposit on the heat element cause the unit to smoke and smell like an electrical fire? And how can. I fix this?
It could be.... It could also be something plastic that got onto the element that is melting and smoking. It could also be a connector to the control board that is loose and is over heating. This is more serious. Carefully check the heating element for some foreign plastic part that is pressing up against it. If there is nothing, then call a professional to make sure that it's not the controller that is overheating and in danger of catching fire.
Jul 27, 2014 | Frigidaire Dishwashers
what can cause the spray arm to get burned? is it too hot water in the water heater or the heating element ?
Aug 29, 2012 | Frigidaire FDB1502RG Built-in Dishwasher
Dish washer gets to hot in pot scrubber mode
did it distort the spray arm? A lot of times if it's the spray arm that melted it's possible that it was jammed while trying to heat the water and the heat from the element would warp it.
Mar 24, 2010 | Frigidaire PLD4375RFC Dishwasher
Dishwasher won't stop running.
Hello there:Its possible your thermostat may be bad, you can ohm it for continuity, take the wires off it first of course.
With the wires off you can even jump it by taping the wires together with electrical tape and run it through a cycle and see if that solves the problem
if not than i would check the heating element
If your water is hot coming into the dishwasher, it should be about 120-130 degrees, and if it is not these temps this would cause the cycle take 3 times longer to finish , then its possibly a bad heating element.
You would need to ohm your heating element for continuity, a good element should show 30 ohms or less.
Make sure the breaker is off to your dishwasher first. Its likely the electrical terminals are in the very back, so you'll likely need to pull your dishwasher out to ohm the heating element. Take the heating element wires off first before testing the element for continuity.
But first feel your heating element all around inside your dishwasher, if you feel bumps on it or pits in it, its definitely your element thats
causing your problems ok
Hope this is very helpful for yo
Best regards Michael
Dec 31, 2009 | Frigidaire Dishwashers
Frigidaire dishwasher heated dry way too hot
Wow. So glad to hear that you had no permanent damage.
Jun 19, 2009 | Dishwashers
Dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Jan 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Dec 01, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Melted utensil on heating element
Hi amsaunders5,
I'm Harvey the Master Plumber.
Your problem is: Children tried to surprise you by doing dishes. The plastic spatula melted and stuck on the heating coil on the bottom
This is a common problem. First, thank the children, it really wasn't their fault.
It's going to take some effort but you'll have to scrape/remove the plstic from the element. Replaceing the element is not a repair I recomend for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
GE PDW9700 - Heating Element turns on by itself and Burns my dishes
have experienced this problem on some zanussi machines. what is happening is that the machine continues thro cycle thinking there is water in machine when there is not. can be caused by:
slow pump rate caused by blockage especially near the drain pump inlet
faulty pressure stat
Aug 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwashers Logo
103 people viewed this question
Top Dishwashers Experts
