Question about GE JE1660 Microwave Oven
No Heat - everything else works
One day the unit was working fine. The next day, no heat. It runs through the cycle and appears to be working, turntable turning, seconds counting down, lights on, making the normal sounds - but the food is still cold at the end of the cycle. I read through all the solutions to see if I could solve it that way. I have tried pressing down on the door while running but this did not help so I doubt it's a door switch. I installed the unit myself when I bought it in 2002, and I have been an amateur radio operator for many years so I feel capable of doing any repairs safely. I'm thinking I may have one of the magnetrons from the bad batch I hear GE got one time, or something else in the high voltage circuit is causing the trouble. Thanks for your help!
  • zebebad Mar 02, 2009
    I have the same problem with a 2006 manufactured GE Microwave over head oven model number JMM1630WJ03, Serial number RL9000440 This unit has only been used just a few times in or winter home as we have only used it 5 or 6 times to heat small things up lioke brand new now it won't HEAT everything eles works but NO HEAT What is wrong with the GE products ? ? ? I am reading a TON of complaints about GE these days , AS LONG AS I LIVE I WILL NEVER BUY ANOTHER GE PRODUCT EVER !
  • GE Master
  • 9,156 Answers
It's most likely a defective magnetron or a bad connection at the magnetron terminal. The GE bulletin on the magnetron kit can be found here to see if yours is one affected: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf You may have a loose and tarnished connection at the FA terminal of the magnetron. If so, it needs to be disconnected, tightened, maybe burnished or sanded, and reinstalled. If it still won't work, the mag is bad. But before you do anything, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Mar 05, 2007
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Magnetron is broken. Replace it with $48 from eBay.
Posted on Sep 27, 2015
Unit will not heat up
check contact points for current. tabs might be bent and are not contacting correctly and no heat the Ni-Chrome wire heats up glow orange when currant is applied , might need a test voltage Meter and screw driver too >^.^<
Mar 14, 2010 | Kenmore Microwave Ovens
I have a 1993 GE spacemaker microwave/range hood combo. Everything works except that for most of the day it did not heat the food. The turntable still worked and the oven still appeared to be running. Then...
In short yes it can happen again.
Intermittent operation can be caused by a door interlock micro switch, a weak capacitor, an intermittent wiring connection from heat or poor connection, a marginally performing diode or a sticking Magnetron. Except for the Magnetron all other repairs would be worth the expense.
Repair costs and parts for most everything else will be between $65 and $100.00 depending on the part(s) replaced. Replacing the Magnetron would cost more than 50 % of the total unit replacement cost.
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Mar 21, 2008 | Microwave Ovens
No heat...
there are 2 fuses inmicrowave 1 for ac input 1 for high voltage transformer that will trigger the magnetron "for heating"
remedy;
uncrew the unit
replace fuse near the transformer this fuse.. usually enclose with plastic casing..
then test..
causes of blown fuse
improper ventilation
Feb 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1660 Microwave Oven Logo
3,241 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
