Question about Samsung SLK407W TV
Discrete IR codes for SLK407W
IrishDurid,
I need to know if Samsung has any discrete IR codes for this TV. Specifically I need the power on and off commands as well as discrete input commands.
Please contact me at n.ortiz76@gmail.com.
Thank you,
Nelson
5 Suggested Answers
SOURCE: I need remote code to unlock Samsung Blackjack SGH-I607
I have the same issue, Can anyone help??? I need a remote code to unlock the mobile phone1.gif (cingular) i have the IMEI.
It's for a blackjack II (i617) and desperately want to unlock it. (my phone w/t-mobile srv. is broken) IMEI 357246014347536 Please help. rakelz1qt@hotmail.com
Posted on Feb 29, 2008
SOURCE: puk code for sgh-t629
you need to get the puk code from your service provider. its a lock on the sim, not the phone
Posted on Apr 03, 2008
DVIroyce
  • 64 Answers
SOURCE: RE:Samsung Model #TCD1341, Manufact./Aug.1995, digital-capable?
No it does not have a HD tuner. The simle way is a Digital Converter box for about $40.00 it will have composit out (red, white and yellow leads) plug these into TV you will have a converted Digital signal that will make your old set
look like a HD set.
Posted on Nov 08, 2009
SOURCE: SAMSUNG DVD-VR375 Change The Region Code to Codeless
i have a samsung dvd player vr375. door keeps opening and closing for no reason, how do i fix this.
Posted on Jan 03, 2010
smozhe
  • 2360 Answers
SOURCE: hello, my samsung t239 imei no. is
Try unlocking sites
Posted on Jan 11, 2011
I had a locked car light come on in my 2006 chevy malibu, it no longer will drive. doesnt turn off, goes in reverse but when in drive, just revs like the car is in neutral, why?
The lock an car symbol is for the anti-theft system ! By not turning off, do you mean you can't turn the key to the off position or you can turn the key to off but the car won't shut off ?
It sounds like you have a Power Mode Mismatch
The ignition switch is an input to the BCM - body control module an if something happens to the system , the BCM will keep the vehicle in the last known mode Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the power mode master (PMM) fail to send a power mode message. The fail-safe plan covers those modules, using exclusively serial data control of power mode, as well as those modules with discrete ignition signal inputs.
You could have an ignition switch problem or something wrong with the BCM .
Discrete Ignition Signals Those modules that have discrete ignition signal inputs, also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 volts, the modules will fail-safe to OFF-AWAKE. In this state, the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
This is one you need to take to the dealer because they have a factory scan tool !
Aug 03, 2015 | 2006 Chevrolet Malibu
Panasonic PT-AE8000U discrete codes
go to www. remotecodelist.com and download for free.
God bless you
Nov 29, 2013 | Televison & Video
Looking for discrete codes for a Insignia NS-L55X-10A. Are there any?
No discrete codes directly. They are manufactured by LG so a lot of times LG discrete codes will work.
YMMV.
Mar 01, 2011 | Insignia Televison & Video
I would like at published discrete code list for a Samsung UN55C800XF TV to program into my Universal Remote MX-700.
Hi.
Your TV is an LCD TV, I do not know if discrete codes are different from ones published for previous model. Codes for this specific model are not yet available on the web, but codes for previous model will probably work (see here).
Codes:
HDTV Televisions (4)
HLN Series HDTVs (14)
HLP Series HDTVs (14)
HLR Series HDTVs (9)
HLS Series HDTVs (21)
HLT Series HDTVs (21)
Have also a look at this thread.
Jul 26, 2010 | Televison & Video
I would like to set the clock on my sanyo 32
The easiest way is some sort of automation system like Crestron or RTI with an astronomical clock and IR capabilities.
You could easily add a timer to the outlet but that will only take the TV from all off to standby. To turn it on you have to send the IR command for power. Also, I doubt the Sanyo has discrete codes for power which will make this impossible to make reliable because if the TV is on at the time you have the automatic power ON it will turn the TV off.
If you really have to do this, here are the parts:
RTI XP8 RTI VS1 Niles MF1 Programming software and a programmer
Nov 24, 2009 | Sanyo DP32648 32 in. LCD TV
What is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
Jul 25, 2009 | Yamaha RX-V563 Receiver
Unable to detect lcd
Replace the Discrete Video card. That's why your LCD didn't detect when you run the Diagnostic test. There 2 type of video cards available to Dell Inspiron 6400/E1505. Either you have a on-board video card or discrete video card. Mostly, the discrete video card is caused when you not getting video output to your LCD (completely dark as if it is off). Discrete video card is detachable and replaceable. Good Luck.
May 16, 2009 | Dell Inspiron 6400 Notebook
Discrete IR code for Current model Toshiba 32" TV
these only work on the latest models HX81 etc...
pon- 0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
pof-
0000 0069 0022 0002 0161 00b1 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0016 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0042 0016 0016 0016 0042 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0042 0016 0609 0161 0058 0016 00b1
Apr 18, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
ILive IT188B - Not a problem, but a question as I have not purchased the unit yet. I am looking to enhance the sound from my Digital TV. The chances of ever using an IPod are slim. My question; can it be...
Yes, absolutely. It has inputs from which you can connect your TV. Its a nice box for the price. The remote SUCKS! Terrible key placement. However, you should be able to program the remote into another universal remote. Although, I have not figured out how to do that yet as ilive does NOT posts discrete IR codes or hex codes for the more advanced programmers.
Feb 24, 2009 | GPX MW3837 MP3 Player
RCA remote with an APEX TV
What is the model number of your TV and remote control? With out that information it's hard for us to figure out the discrete codes you need in order to program everything to operate.
Otherwise you can always quickly notify the manufacturers customer service over the phone what products you own and they can offer you the discrete codes over the phone for your convince as well. Some people find that easy in case you do not know where to find your product model number.
Keep us posted!
May 26, 2008 | RCA RCR311B Remote Control
Samsung SLK407W TV Logo
63 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
