Question about DCS RDS-486GD Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
12 inch door problem on model RDS-486GD dual fuel
The small door will not seal because the 2 screws at the bottom holding the door hinges are stripped and keep getting pulled out. Therefore the top of the door stays open a bit, making it no good for cooking.
    Habit-Forming:
  • 171 Answers
You can take one of the screws to the hardwere store and get a self taping screw, or a screw one sides bigger. or you can use a ribbit, that will take care of it.
Posted on Dec 12, 2008
DCS RD 486-GD Oven thermostat small capillary torn. where can i buy for replacement of thermostat.
Hello everyone,
I am looking for Capillary temperature control Thermostat. nybody knows where can I find this part in Toronto?(GTA)
Thanks
Manoo
Nov 23, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
Kenmore refrigerator model 253.7481240B Having a problem with the doors not staying closed. I received new door seals but that doesn't seem to be the problem. The doors don't seem to be level. The...
You should level your door first This is probably the problem. There should be a cosmetic plastic cover over your top hinge remove it by prying it off then there should be 3 10mm or 5/16 screws that hold the door hinge on loosen them slightly and move the door to level it may help to have someone help you hold the door but normally the magnetic strip in the door seal will hold it. When its level across the top retighten the screws. If I need to clarify something just let me know good luck
Aug 16, 2010 | Kenmore Refrigerators
All 6 ranges and the large oven work well.the small oven won't li
My gas oven stopped working properly - called in the repair man and he replaced two of the three ceramic ignitors. (I have a two oven model). Apparently they only last / work well for 3-5 years. Kinda sounded crazy to me - but verified on the internet they are required to be replaced. Not sure I'd call the repair man next time - get the part yourself, one screw & two wires to replace. I'm no expert - but that solved my problem.
May 22, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
Dishwasher leaking
This sounds like a hinge problem to start with.
Test the seal by dragging a strip of paper through it with door closed. Probably that left hinge isn't holding door close enough which was probably the original cause. As seal dries out a bit then will leak.
At this point I would investigate the hinge possibility AND if possible a DIY fix. It may be loose mounting screws or take a little shim to hold the left corner tighter. I would not waste money for a service call.
You probably might need to release the door balance springs accessable under the toe kick area while working on the door. Possibly a hinge is bent.
You might do as they do in the auto industry when a door doesn't fit... basically put forces on it to bend it a bit. In your case it would be to distribute the load and support the door when horizontal about 6 inches out from the left hinge and then bend the end of the door down to bend the hinge mounts slightly..
Then check the seal clearance with the strip of paper as you do with a refigerator seal by cloosing on a strip of paper and dragging the strip to see if it is gripped.
May 13, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
One of the hinges on the door seal has come off and the door will not close properly. Model #KFCS22EVMS This model has the sealing mechanism on the left door where a small panel slides into the body...
Open the little metal screw on the larger hinge that is between the top and bottom hinges. This will allow to pull the seal all the way out. There is wiring behind that middle hinge so watch not to damage it. Then , you can realign the 3 hinges in their place and replace the screw in its position. It takes a little bit of patience to realign the 3 hinges but it's very doable.
Dec 23, 2009 | KitchenAid KFCS22EVMS Stainless Steel ...
Freezer door will not stay shut is their a replacement for the maginetic strip bottom freezer small
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 21, 2009 | GE Refrigerators
Kenmore 596.50692000 refrigerator. Every time I shut the refrigerator door, the freezer door pop open. What can I do? Do I need to replace the magnetic strip around the door? Who can give me instructions?...
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Let me know if this helps, Thanks, Sea Breeze
Mar 25, 2009 | Kenmore Refrigerators
Kenmore Frig-bottom freezer/freezer door pops open
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Feb 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Frigidaire 40 inch range model #REG46NW-2
OPEN THE DOOR COMPLETELY. IF IT GOES BEYOND HORIZONTAL, THE HINGES ARE BENT FROM EXCESS DOWNWARD FORCE. THEY WILL HAVE TO BE REPLACED.
CHECK THE DOOR HINGE SPRINGS TO MAKE SURE ONE OF THEM ISN'T BROKEN. IF YOU FIND ONE BROKEN, REPLACE IT.
Mar 31, 2008 | Frigidaire PLCF489AC Dual Fuel (Electric...
DCS RDS-486GD Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
110 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
