Question about Mashida LCD TOUCH-PANEL TELEPHONE Remote Control
Need to know who manufactures mashida lcd flat panels?
I too have a LT200 20.1 inch tv .i would like to know if there is a away to use it as a monitor for my pc even tho it dosent have any dvi or vga outputs !#@$!~#~however.... it does have s video coposite videoin/out ..also component in..... can anyone help me thanxx
Hello Brett, recently I was given a SANYO LCD FLAT SCREEN TV MODEL:LCD-46XR10F; 46 INCH SCREEN MANUFACTURED OCTOBER 2010 BUT it had no Manual so need help to acquire one please. Rowena
Manual U get from the manufacturer web site.
The tv does not record the program. That is done by a dvr and then PLAYED back on the set.
Mar 10, 2016 | Sanyo Televison & Video
I have a 55 inch vizio flat screen. it turns on but the screen fades away.
//If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 22, 2014 | Sanyo DP50747 50 in. Plasma TV
Tv comes on but screen fades away
...If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Dim screen
- Slow start
Apr 22, 2014 | Televison & Video
Whire vertical band , 3 inches wide with red kine in the middle
- Flickering screen
- Dim screen
- Slow start
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
I have access to a Mashida telephone XH-301A but do not know how to use it. Can you please tell me where I can get a manual? Thank you, Betty Doyle
Hello
There is no serch result to your Mashida telephone by google search. Just get into this Maschida site, and search for your device. There are many options to select in different pages. All Mashida products are listed there. OK
Aug 27, 2011 | Mashida LCD TOUCH-PANEL TELEPHONE Remote...
Brand new Hannspree 28" tv when you switch it on screen just changes colour white to red all colours and nothing else
Get rid of this model!!!! The Hannspree and Toshiba models used a TFT LCD screen from a chinese manufacturer that has put out faulty components for the last 3 years. The Problem is in the way the Active Matrix Screen was manufactured. I would recommend you return this item immediately to the place where you purchased it and pick a different brand; also stay away from Westinghouse!
Sep 24, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
LCD monitor will not get picture
Burned out Backlight Fluorescent Bulbs. Check ebay.
Jan 21, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
I have a funai 20" , given as a present - threw away the instruction booklet !!! need to adjust the colour brightness and don't know how ! Please help !
Funai is a major manufacturer and has a detailed website. Log on to their main page and follow the links starting with 'Support.'
Dec 15, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HDTV?
HD ready?? NO - - Compatible? Yes but you'll need the converter.. The US post office will be giving away coupons for the converter. Google search the HD converter issue and you'll have a wealth of information.
Bill
Feb 03, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Televison & Video Logo
21 people viewed this question
Top Mashida Televison & Video Experts
Are you a Mashida Televison and Video Expert? Answer questions, earn points and help others
