Am having problem installing camera cable in USB port - goes part of the way then it feels like I am heating solid area - have been trying for days off and on. Please cn you help?
  • vachaffin Dec 11, 2008
    cancel - my computer guy is coming by - thanks anyway.
    Genius:
  • 1,199 Answers
This sounds like your usb port or cable is damaged Try another cable ....or port!
Posted on Dec 11, 2008
  • 38 Answers
If you have another usb socket in your machine then you could try the plug in there, it would be worth trying another usb plug in the same port and see if you can feel the same resistance.
check the usb plug and port on the machine to make sure that neither are damaged (if you have a torch you will find it usefull at this stage) look inside to make sure the metal surround has no dents or bends in it, also check the gold coloured contacts (there are 4 on the inside of the plug and socket) and just make sure that you have it the right way around (half of the inside of both socket and plug are filled with plastic so it can only be inserted one way)
If you find that the plug on the cable is damaged then unfortunatly it will need to be replaced, however most cameras have generic usb cable which are cheaply available.
I hope that helps you with your problem
    Genius:
  • 1,847 Answers
Wht is the make and model # of the camera?
  • 13,433 Answers
Hi, try another usb port and look into the usb connector at both ends, is the connector broken? does another usb device fit in normally?
  • Ekse Dec 11, 2008
    The connector is obviously broken or your missing the software.
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
I have i ball C8.0 face yo face webcam.the software got installed from the CD, webcam is also connected to the USB port but on opening the window an error occours that you have no video capture device !...
Just uninstall the camera driver and disconnect the usb cable of camera. Restart the system. and after restarting the system 1st install the driver disk and then when it prompts to connect the cable or after finishing the installation connect the camera usb cable and follow the instruction.try with different usb port.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 14, 2010 | Intel Computers & Internet
Unknown usb device... It startet the other day. i got it to work the other day, i connected to another usb port. But today it says the same in all usb port. Have tryed to download and install the newest...
Optional solution actualy, this is,the usb cable that goes to the printer maybe has been fucked up because of bending and such **** like that try another usb cable that even might work
Jan 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Bad USB Port in Camera
With that amount of non-accidental damage, a replacement is the best option financially
Mar 05, 2017 | HP E427 Digital Camera
I have connected my FinePix digital camera to my Windows PC and I still can't view the images on the SmartMedia or xD-Picture Card. What should I do?
If the images on a SmartMedia or xD-Picture Card fail to appear when the camera is connected to a Windows PC, one of the situations listed below may apply. 1. There may be a problem with the SmartMedia or xD-Picture Card. Check that the images can be viewed on the digital camera. If the images cannot be viewed on the digital camera, gently wipe the gold colored contact area on the SmartMedia or xD-Picture Card with a soft cloth and then check again. 2. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. * This only applies to models with a USB Setting or USB MODE option in the SETUP screen. 3. Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow is shown on the LCD monitor)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. 4. The USB driver may not be installed correctly. Download the USB driver from the Fujifilm general downloads web page and re-install the driver. 5. The card may not be recognized correctly if the camera is connected to an added USB interface board or via a USB hub. Always use a factory installed USB port and connect the camera directly to the USB port on the PC.
Aug 30, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Aug 30, 2005 | Fuji FinePix 2400 Zoom Digital Camera
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
