Question about Car Audio & Video
Pioneer DEH-p4600 My friend just bought a car and it came with this head unit already installed. We can't figure out how to remove the faceplate. Can you help?
    President:
  • 624 Answers
In the top right corner of the display is a small button that you push in and the face will drop down, this is for putting a cd into the unit and also for taking the face off. Once the face has dropped down you just pull it off. It will come right out. To put it back on again just place it back into the holder with the right side going in first and push it until it clicks into place. It doesn't take a lot of force to put it on or to take it off. If you are still having problems with it you may need to take it in for repair. But usually if the face is having problems with how it is attached, the problem is that the face will not stay on.
Posted on Dec 12, 2008
Hello, I have an odd problem with my Pioneer DEH-P9800BT Screen
Clean all contacts chemically and check all wiring for good, tight connections.
Aug 25, 2017 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
I am unable to reset my pioneer deh p4100. I see
remove the unit and disconnect the battery+red and yellow cables.check the front unit for derfomed plastics or stucked somehow microswitches!someone stucked from the heat!
Jun 05, 2010 | Pioneer DEH-P4100
How to reset my DEH-P5000UB, because my display turned off, weird
Re:"everyother light turns on the faceplate but the display is off"
That means that the unit is either faulty, or one of the two powered lines required had not been connected.
The unit is reset by simply disconnecting the connector at the back.
This will not help in fixing the problem.
Ensure that unit is wired properly. Use a voltmeter to test wiring.
Here installation manual with proper wiring.
Here also the owner manual.
May 26, 2010 | Pioneer DEH-P5000UB Car CD/ MP3 Player
I have lost the faceplate for my 08 Pioneer DEH-P4050UB
Time to get a new head unit! In all my years of installing car audio, unless you know someone with a faceplate from an old broken unit, you'r out of luck. If you do find a source for just facerplates, please let me know
Feb 01, 2010 | Car Audio & Video
Same thing jus happened to me this weekend.
Normally, on removable faceplate models, there is a reset button on the unit visible with faceplate removed. Press reset. This will clear all programing back to factory settings.
Sep 22, 2009 | Pioneer DEH-1900MP CD Player
I own a Pioneer DEH-9650 and want to connect Apple ipod touch.
Hi I was wondering were can i buy any one of these head units, i really want the Pioneer Deh-p9650. but i cant not find one place were i can buy it. i usto have the 8400mp like 6 or 7 years ago but i sold it and now i want a nother 1... i would really like to buy the Pioneer Deh-p9650mp so if any one can point me in the right direction i would be more then greatful.
thanks
DEH-P9650MP ??
Sep 14, 2009 | Car Audio & Video
Remove basic unit from the housing in the dash
you need two little flat pieces of metal that slide down each side of the unit to release the clips these come with the radios usually if you know anyone that has purchased a pioneer head unit you should be able to borrow them to do it. if not go talk to any install shop they have them laying around and will sometimes part with them. if you cannot get ahold of them you will have to remove your dash and pull the bolts out and remove the entire chassis to get at the back then reinstall it. you did not say which car you have so i cannot help with the dash removal.
May 15, 2009 | Pioneer DEH-P2500XM CD Player
Unit powers down when faceplate attempts to go to open position
Same thing happened to me twice.
Its the crappy ribbon cable that connects the faceplate to the head unit.
Its only about $12 (USD) from Pioneer directly.
http://parts.pioneerelectronics.com/part.asp?productNum=GXY1005
It comes with instructions, its not that difficult.
Best of Luck.
Please RATE my solution BELOW.
Nov 20, 2007 | Pioneer DEH-P840MP CD Player
Pioneer DEH-P6900UB
make sure that you have power not only to the red wire but also the yellow wire... one is battery power the othe ris ignition on power. If it only is getting one power it might not think the ignition key is on.. also maks sure there is not a reset button somewhere that you can press with a pen...
Aug 27, 2007 | Pioneer DEH-P6900UB CD Player
Auxilary
If your cd player is a DEH-P4600MP (mp3 player)then you have to turn off the player first, then press the button on the upper right hand corner of the faceplate and then scroll through the menu and find aux to turn it off or on with the "wheel" on the right on the faceplate. You will also find the alarm and clock settings there in the menu as well but the key is to make sure the player is off first while doing this or you can't access the menu. To use the auxillary input on the back of the unit you need to purchase (eBay has them) an aux input adapter ref CD-RB10 cable. Hope this helps.
Aug 01, 2007 | Pioneer DEH-P4600 CD Player
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
