Question about Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel Washing Machines GWL11 Top Load Washer leaking
Looks like the water pump is leaking every time it goes through the rinse cycle. Would rather repair if possible because this is only the 2nd breakdown in 25 years.
  • mkm31 Jul 16, 2012
    My apologies - my machine is actually a GW52F Fisher and Paykel Wahing Machine
  • Fisher and P... Expert
  • 555 Answers
Pumps are the most common faults in these machines.
Posted on Dec 26, 2013
SOURCE:
IFIXALL
  • 869 Answers
SOURCE: Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
Posted on May 25, 2008
gittos73
  • 244 Answers
SOURCE: Fisher & Paykel "clog Problem"
the water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
Posted on Aug 12, 2007
SOURCE: Fisher & Paykel Washer Model GWL11
Clebinla,
I have the same problem with our GWL11. It just started yesterday. I think I found out where the problem is occuring. I noticed that there seems to be a crack in the small rubber tube that supplies the fill water. The water leaks out of this crack and runs down the back of the machine. I fixed the problem temporarily by putting a piece of plastic below the cracked tube that funnels the water into the tub. I am trying to locate a replacement for the tube but I haven't had much luck yet (it is a curved yellow tube that is a couple of inches long.)
Posted on May 11, 2008
  • 1028 Answers
SOURCE: Fisher and Paykel GWL11 Question
no belts ..direct drive ..lean washer back pump is a twist lock no tools needed hose clamp can be removed with fingersremove pump and ck for lock impeller also ck the diverter valve just behind pump
Posted on Jul 17, 2008
ngfam1
  • 639 Answers
SOURCE: Fisher and Paykel GWL11 will not drain...
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washer stuck on rinse cycle. Wont advance. Pump fine. Could it be the diverter valve. Took it apart and it was clean, no broken parts.
Check your belts, maybe belt slipping or pump jammed, if okay replace the electronics board. You can fry your electronics board if the water pump becomes jammed for any reason
Nov 08, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hello my Fisher Paykel washer will go through the
clean the pump at the bottom of the washer (its the piece with the fan attached); also check the hoses at the pump
Jun 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Leaking Washer
Changing this solenoid could solve your problem. Also try to turn off your faucet if possible after you hv finished your washing.
Dec 24, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
281 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
