Question about Gateway DC-M40 Digital Camera
Hi, I was taking pictures with the camera them all of a sudden the lens would not return in. I have tried new batteries with no avail. When I press the on button the light comes on and it sounds as though the lens is trying to do something but then the light goes off again. No pictures come up on the lcd screen either. Hope you can help. Thank you, Julie
  • 4 more comments
  • bettybonny Dec 30, 2008
    i have the same problem
  • Anonymous Jan 04, 2009
    batteries died and then the lens stuck so annoying
  • abererch Jan 14, 2009
    Daughters camera comes on, beeps a few times and the lens won't come out. Then it switches itself off. I have tried new batteries etc., and they don't solve the problem
  • Anonymous May 09, 2009
    i have the same problem... must be a fault in this camera.. its happend to before before and ive had to take one back
  • yieldband May 09, 2009
    lens is stuck and when you try to turn it on it beeps 3 times then turns off!
  • Anonymous May 21, 2009
    Is there anyway you can fix this probolem, without it costing me a fortune for a new camera?
5 Suggested Answers
SOURCE: Lens error displayed by coolpix 3700
I have a Nikon Coolpix 3700 camera which had a LENS ERROR message on display when opened.
I tried various from site ie;taking out the battery and then the memory card and then inserting the battery etc, nothing worked.
Then I tried powering on the unit and at the same time shacking it/hitting it on my thigh and couple of goes at this....... boom the shutter opened up ! Then I powered it off/on several times to test if it works and YES it works perfectly fine. Hope this helps.....
Posted on Feb 12, 2008
  • 903 Answers
SOURCE: Samsung S1065 does not turn
I had the same problem, firstly you will be able to press the button on the back to view your pictures, when you do and the camera powers up quickly press the menu button. Check that your battery settings are set to alkaline, then buy some good alkaline batteries and not cheap ones. Check that they are alkaline and not like what I did and bought panasonic zinc carbon.
This worked for me and mine would not turn on either until i changed the batteries to a good make.
Posted on Oct 12, 2008
  • 4 Answers
SOURCE: my samsung s1065 lens wont shut and anytime i turn
tried above,but 3 beeps and dead camera has shown up on numerous forums from many s1065 owners so got repair under g/tee. if it happens again i'll have a replacement !!!
Posted on Jan 02, 2010
  • 11967 Answers
SOURCE: my samsung s1065 camera has frozen, new batteries
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 08, 2010
Samsung x860 digital camera lens stuck
Time for serious repairs or a new camera.
Nov 28, 2012 | Samsung S860 Digital Camera
Samsung S1065 digital camera. Won't witch on. Len won't extend, beeps three times, switches off. Any ideas gratefully accepted.
my samsung camera s1065 the lens wont extend when switching on the lens does not extend ,it bleeps 3 times but then closes down
Aug 28, 2010 | Gateway DC-M40 Digital Camera
Samsung S1065 beeps 3 times and nothing else
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 11, 2009 | Gateway DC-M40 Digital Camera
770SW Olympus needs a factory reset, lens stuck open
Contact Olympus for the factory reset code.
Sep 01, 2017 | Cameras
Lens stuck
First, if you can, try to save the pictures on the camera to something off the camera. Then, on the camera menu, navigate to the RESET menu option and select it. The camera should reset and hopefully it will function properly. If this doesn'r work, then the camera will have to be repaired or replaced.
Jun 13, 2009 | Samsung S1070 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Lens is stuck, and won't focus...
how to solve this cam yesterday cam slip from my hand so not working i buy from saudi arabia 2 month before so i want solve the problem
Dec 10, 2008 | Samsung Cameras
Samsung S1065 does not turn on, beeps 3 times before powering off. Lens is extended, have checked batteries, not sure what else to do??
Oct 01, 2008 | Gateway DC-M40 Digital Camera
there are two possible problem of your camera...change first the lens or try other lens if you have,normally the lens have an error is on wide position...if nothing happen when you change the lens the possible problem is the shutter of the camera.......
Aug 24, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Gateway DC-M40 Digital Camera Logo
576 people viewed this question
Top Gateway Cameras Experts
mohamed salim shaikh
Are you a Gateway Camera Expert? Answer questions, earn points and help others
