Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
Tape End Sensor Error - UVW1800
Help!
Have not used use this VTR that much recently, has low hrs. and I'm attempting to transfer tapes which apparently have slack issues. 1st 2 of 5 tapes gave a slack warning. I had to take loading mechanism apart to remove tapes twice. Now tapes won't load and I get Error message 32-000 Tape End Sensor Error and going further into the diagnostic menus I also see S-Reel Error. Any suggestions would grreatly be appreciated.
  • pvp1 Dec 15, 2008
    Also getting an additional code- ERROR 09-209.
    Any help would be appreciated.
    Champion:
  • 221 Answers
These error codes point to possible problems with one or both reel motors.
Posted on Mar 13, 2009
Sony HVR-A1U "Reinsert Cassette" Error pops up frequently
I have had this error on my 3 year old Sony A1E and it has resulted in glitched picture and audio, despite not showing a poblem whilst recording. It came up with C:31:23 error. Start of the tape seemed ok and the end seemed to get pixellated. A friend said the PD170 had the same issue and had to have her tape heads changed. I've tried cleaning mine but problem still there. I'm looking at getting new NXCAM as I've spent a lot of money last year getting it fixed.
Jan 06, 2010 | Sony HVR-A1U Camcorder
Can't open door - can't eject tape
How old is your camera?
Seems it has weak capacitors in circuit.
Oct 27, 2008 | Sony Handycam CCD-F555 Camcorder
Sony UVW 1800 error code 02-403 - tape is out, code won't go away
Error 02-403 is "tape slack in ff/rew". Although you were able to get the tape out, the threading ring may not have returned to the unthread position. With the power disconnected and the top of the deck off, look at the mechanism; on the right side, there is a small gray motor with a black wheel in front of it. By turning this wheel, you will be able to make the threading ring turn; turn it so the ring goes clockwise. When the ring has gone as far as it can, it will be in its unthread position, and the deck will probably work normally.
Dec 17, 2009 | Sony UVW1800 VCR
Mini DV Tapes are not playing back. Nothing but blue screen when I try to view tape...no time code...nothing. Recently recorded footage plays back fine though?????
If recently recorded plays back ok, and there's no warning about low rf or head clogging problems,it seems to be electronic problem in vtr board,but usually is head problem,which is not so expensive.
Jul 30, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Jul 02, 2009 | Sony UVW1800 VCR
UVW-1800 SONY VTR - s-reel error
Both these error codes indicate a problem with the supply reel motor.
The first code (02-058) indicates that the reel motor is drawing too much current, which could be caused by a bad motor, defective driver circuit, or even a bad tape. The second code (02-803) indicates tape slack, caused by the defective supply reel motor. FIRST thing to check would be a possible bad tape. Try different tapes and see if the problem persists. If it does, it may be time to find a technician.
Mar 16, 2009 | Sony UVW1800 VCR
I have a digital video camera DCR-TVR140 and when I put the little casset on the screen(on center) appear a litttle arrow blinking and also a beep beep sound for maybe 5-10 seconds and still like that with...
Do you see any error number on LCD such as C32:11
If no.
1) It could be the Digital 8 tape is at the end set the unit on VTR mode then rewin the tape
2) The tab for record protection is on that mean the red tab at the right hand side full red indicated SAVE just turn to REC position in this case you can try on VTR mode it should work
Dec 01, 2008 | Video Cameras
Error Code: 3271
SONY DSR 45
ERROR CODE 3271
Oct 16, 2008 | Sony DSR-45 Mini DV VCR
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Feb 22, 2008 | Sony Betacam SP Small Videocassette 30...
Reinsert tape message
I got the dreaded reinsert tape message today and i thouht that my video taping days were over. i then made my way to this page and saw this. whack it three or four times and it will work. at first i thought what a load of crap but i tried it anyways... being really mad at the time, i showed my camera no mercy. i took out the tape and gave it 4 hard hits with my palm, put the tape back in and it worked. thanks alot, this works
i
Aug 11, 2007 | Sony CCD-TRV138 Camcorder
Electronics - Others Logo
835 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
