Question about Samsung DLP HL-P5663W 56" TV
Our Samsung HLN617W DLP TV won't turn on!
Hi-
Our television worked fine last evening. This morning when I went to power it up, it made its usual noise but there was no picture. The small round panel on the front showed a green light with a red light underneath. I tried to hit the power button but it was as if it had no power and nothing happened whatsoever. I unplugged and replugged and hit the power and nothing; however, the lights in the panel shut off. Now when hitting the power button, it's as if it has no power at all as though unplugged from the supply. Any help would be greatly appreciated!
Happy holidays!
Merry-
  • NoTVForMeee Jan 06, 2009
    my Samsung HLN617W wont turn on either! There is audio, and the green "lamp" light keeps blinking and it powers on and off on its own...but all i hear is audio! whats wrong with it!?
5 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Samsung TXN2726 TV Does not turn on
This denotes a power supply problem. The trouble could be in the low voltage or the high voltage supply. You will need a schematic and at least a multimeter to even beging to troubleshoot this problem. If you do not have a background in electronics. I would suggest taking the set to a TV repair shop.
Posted on Sep 22, 2007
SOURCE: TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Posted on Dec 10, 2008
SOURCE: DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Posted on Jan 27, 2009
SOURCE: samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Posted on Apr 10, 2009
asnowman
  • 788 Answers
SOURCE: Samsung HLN617W Tantus 61" DLP occasionally will not turn on.
It sounds to me like you have an issue with the ballast not firing the lamp. It sound like you know to check the lamp, but there is no way to check the ballast, unless you replace it. The ballast is not that tricky to replace, but if you are not sure I would refer you to a technician to replace the part.
Posted on Apr 30, 2009
I dont have an answer yet
A number of Samsung projection TV and LCD TV had bad capacitors. There was even a class-action lawsuit (which is over). It happened to one of mine. If you open up the TV and find the control board you will fine 1 or 2 capacitors that have split on top like a little mushroom. I have them replaced and the TV woks just fine. Amazon even has kits if your a DIY person and can soder.
May 16, 2014 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w TV Dlp lamp won't turn on already replaced lamp, ballast, color wheel
It sounds like the main power supply has a bad capacitor. its a typical issue with a lot of electronic. look on the main power board that the outlet cord comes in to the TV and check all the cylindrical components for swelling, leakage, or singe makes.
Dec 13, 2013 | Samsung HLN617W 61" Rear Projection HDTV
Samsung dlp hln617w does not tun on
this model number do not use lamp ?????????
Jun 09, 2010 | Samsung HCL4715W 47" Rear Projection...
The bulb has been replaced within the last 3 months and everything has been working fine. When I turned the TV on just now there is a buzzing sound sounds like a motor is running and continues to run for a...
Ur colors wheel it dead.It spinning of it axes.The noise u hear it the grinding of the colors wheel.There no colors,big buzzy loud noise,or grinding noises.In any kind of DLP tvs that produce the last 10 years they all have colors wheel's.Hire a Tv repairman for this job.Because it require alot of taking out of machanical parts,even can come to the colors wheel part to replaced.Many people made a mistake think it was easy,cost them alot more $$,because tv's tech. don't like fixing other people mistakes,and blunders.Give them a head aches tries figure out what the customer did.
Apr 10, 2010 | Samsung HLN617W 61" Rear Projection HDTV
What does it mean when your tv is on and working and then the screen turns into white dots
white dots are usually caused by a defective dlp chip. very common problem with samsung dlp's. samsung will cover the cost of parts and labor for this problem. call 1-800-samsung to set up service.
Dec 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Lights light but TV won't turn on. Worked fine last night..what went wrong
if you have no picture, it's probably the lamp, ballast or power supply board have gone bad.you will need a tech. to figure it out.
Nov 02, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLN617W TV does not turn on, all 3 lights flash
In this case it seems you may have an issue with your ballast. Either it's going out or barely starting. I recommend you replace it
Aug 06, 2009 | Samsung Televison & Video
Samsung DLP model hln617w won't turn on (not bad bulb)
Samsung is notorious for having bad color wheels in their DLPs. Well lets just say they are like toasters, they only last a certain amount of time. If the color wheel isn't spinning or is broken, the set will power down almost immediately after you hit the button, you may not even hear the entire fire up jingle. Check the wheel, if you can see the bulb light up for that split second. Actually, check it whether the bulb lights up or not.
Jun 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
61" Samsung DLP w/ no sound
my speakers died some time ago, it wasn't worth fixing, went to a component 5.1 speaker setup. good luck.
Aug 15, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
275 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
