I have a Dimplex XL5N storage heater. When i first moved in it worked. Now i am getting now heat i've rang up Dimplex they told me to put the input switch on maximum and the output minimum in the night. Then switch output to what heat i want in the day. but still no heat, the fuse is ok. What else could the problem be & how much will it cost?
kevin000
  • 1847 Answers
SOURCE: dimplex heater model no -CHT20 will
did you try it on a different wall socket.Chk the power supply fuse
Posted on Aug 09, 2008
SOURCE: my dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Posted on Feb 13, 2009
crouchdash
  • 83 Answers
SOURCE: 3 amp fuse blowing in York central A/c
a blown fuse is a sign of a short circuit. either connections are touching each other or a relay is busted. Have it checked. Have the system leak checked also, this would result to better cooling/heating and energy savings.
Posted on May 13, 2009
SOURCE: My dimplex night storage heater is not heating up,
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Posted on Jan 19, 2010
  • 1015 Answers
SOURCE: hi. i recently moved into
Is this also controlled by a seperate thermostat ? Is so make sure it is set up to call for heat. Hope this helps. Thanks
Posted on Nov 21, 2010
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
Hi, I have recently moved into a new flat with simplex storage heaters, however the letting agent has no idea how to use them and the landlord is away. They seem to be really old models which you turn on...
Here is a link to a video that will help you understand the theory of how the Dimplex Storage Heater works. It may be a little newer than the model you have, but it does the same thing.
http://www.youtube.com/watch?v=bXrbk-cPWG0
I hope this was of help to you and tanks for choosing FixYa.
Sep 20, 2011 | Heating & Cooling
Hi I have a night store heater model 79168 in my new home and no idea how to use it!! Please help :)
Here is a good article for Dimplex, a storage heater manufacturer, that explains the the theory and how it works. I'm sure you will find it interesting. http://www.dimplex.com/storage_heaters#
Basically, thermal storage heaters heat ceramic bricks during off peak hours (during the night), store the heat to be used during peak hours (during the daylight hours), when electricity is more expensive per kilowatt hour.
Hope this helps you.
Apr 18, 2011 | Heating & Cooling
My dimplex xms718n storage heaters are not heating up properly - the bottom half is still cold in the mornings what could be causing this?
I have recently had xms718n storage heaters installed and about once a week none of them seem to come on at all. Do you know why?
Dec 09, 2010 | Dimplex Heating & Cooling
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
Dec 19, 2009 | Dimplex Heating & Cooling
I have two dimplex XLN storage heater, it was working last year but after someone put damp clothes on it, they are not working, could you help me please
It sounds as though it has tripped the internal cut-out - this can be manually reset quite easily by yourself. It would probably be best to ring Dimplex customer services on 0845 6005111 to get them to talk you through it step-by-step though.
Dec 18, 2009 | Dimplex DS5603 Heater
Hi, I don't understand how the early and late boost works on the storage heater. Someone told me I should turn the output switch off when I am at work during the day, then turn the output control up when I...
Output switch is the one that says Cool-Off-Heat. Turn this offwhen you aren't home.
Output control is the thermostat. If you want to heat the room turn up the thermostat to the desired heat after putting the output switch on heat. It will take a few minutes for the heater to get hot. Early boost would be if you want immediate higher blower speed to speed up keep the heated air from being too hot and late boost will hold off the fan until the heater is higher in temp and the air temp discharged will be hotter.
Nov 19, 2009 | Dimplex DS5603 Heater
This question has already been asked, but I am still unsure .I own a flat with a Dimplex night store heater. It has two dials. One is 'Room Temp Boost' and the other is 'Input'. 'Input' is obviously the...
it does not relate to the time of day it relates to the temp in the room
as you know most heaters do not run continuously, they cycle on ambiant temp.
the boost setting is actually tweeaking that cycle,
you are actually setting the vairence in the temp setting
each modle is slightly differant but
here is an example
9 late boost, might let the temp differential drop as low as 25 degrees
1 early boost might only allow a 2 degree differential
Oct 27, 2009 | Dimplex DS5603 Heater
Dimplex night storer, how does it work?
Are you setting the input to maximum and the boost to late? You do not say what size the heater is in either kilowatts or kilowatt hours eg 2kW or 18kWh. These heaters will tend run out of stored heat in the evening especially in colder weather.
Jun 08, 2008 | Dimplex DS5598 Mid-Size Heater
Early / Late boost in dimplex storage heater
The output setting if turned off isn't adjusting the temperature in the room automatically if its off,and by turning the output up is like turning up the heat.By turning the output switch on you can let the heater automatically control the heat.Still you need to monitor the adjustments to your liking and then you know how hot it will be when you come back into that room.
May 26, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
1,052 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
