Question about GE 24 in. GSD4020Z Built-in Dishwasher
GE diswasher GSD4020Z02BB doesn't completely drain
Dishwasher runs but doesn't drain completely. I have check the drain in the dishwasher (pumped out with wet vac) and no clogs. I have checked the line into and outof the garbage disposal (no clogs). This system doesn't have an air gap to check. I can see the water draining into the garbage disposal when it runs but the dishwasher doesn't drain completely. Could it be the timer? The float system? I am not sure what to replace but I know I can handle simple repairs.
  • 1 more comment
  • Rick Sturm Mar 05, 2007
    catdriver, I appreciate your prompt response. The part number you gave me, WD24X220 doesn't match the ge web-site, which has a part of WD24X10018. Is your part a sub-assembly number. Also you said it goes under the screen at the rear of the dishwasher but I am not sure where exactly you are referencing. For GE's web picture, I can see the assembly but not where it goes. And I have had the rear screen off for cleaning but don't remember seeing this part. However the water was dirty so maybe I missed it. Any clarification would be extremely appreciated.
  • zeitgeist Jun 11, 2008
    I have a GE Nautilus built in dishwasher that doesn't drain, either. I checked the drains for blockage, and didn't find any. I haven't checked the drain hoses yet, but I may try the solution posted on this page.
  • mjsocier Sep 19, 2008
    i just hooked up a GE dishwasher that flows into a garbage disposal. i have no air gap. the water pools and does not drain. i unhooked the drain hose from disposal and turned on machine, then water will drain in a bucket. the directions say to remove the disposal drain plug, is this plug set in a couple inches because i can stick my finger in an inch or so and feel a plug unless it is a check vavle. any suggestions? thanks model is gld4450
  • 3 Answers
This is exactly what happened to me and I paid the repair man. Learn from me. Open dishwasher, unscrew screen along back of dishwasher. Piston assembly should be right there. Part is WD24X10018. GE will charge you $17 plus labor. Can buy it on-line for around $12. Takes about two minutes to fix.
Posted on Jul 08, 2010
    President:
  • 878 Answers
Rs, in the back under the screen is a piston nut assy. This is a common problem on these GE's. The seal on the assy. becomes warped or worn and when this happens we get water left in the tub after drain. It's an easy fix. The screen comes off and the pistion nut assy. simply unscrews. The part number is WD24X220. You can look it up on the net, inexpensive. Catriver..post back.
Posted on Mar 05, 2007
  • Ron Marek
    Ron Marek Mar 05, 2007
    Check out this link http://www.repairclinic.com/0080.asp
  • Ron Marek
    Ron Marek Mar 06, 2007
    rs, it's possible that the part numbr changed. but it will look like the one in the link that I sent you. In the tub area in back right hand side there is a filter screen. Remove the screen. In the sump area near the left side is the piston nut assy. This unscrews and lifts out. Replace it with the new piston nut assy. Catriver.
Catdriver is correct. For my GE model (GSD4020Z07BB) , there are two filter baskets. There is one in the middle (2 screws), and a long one in the back (4 screws). I removed the middle one and cleaned it out. The back one contains the piston nut assy (which I purchased on Amazon) part # WD24X10018. The piston nut was difficult to turn, so I had to use a screwdriver and hammer (placing the head of the screwdriver against one of the tabs, and hammering) counter-clockwise). This loosened the piston enough to remove, and replace with the new one. Everything is now working back to normal, thx to catdriver.
Posted on Nov 18, 2010
  • oncearunner Dec 05, 2010
    Thanks for the tip. I was able to easily (no hammer, just fingers) remove my piston nut assembly, clean it and problem solved. But I did notice some wear on the assembly, probably causing it not to seal correctly, especially after a 2-3 week period without use. So I have kept the part number saved in Amazon for quick purchase if the problem re-occurs. Thanks for suggesting Amazon and providing updated part number. It was helpful to 'see' the part and go from there.
If you talk to your repairman, he will explain to you that it is suppose to not drain completely because it keeps the rubber and other parts wet so it will not deteriorate. It is supposed to keep a small amount in the bottom. We have had ours for 11 years.
Posted on Sep 27, 2008
Stop all cicles with code C5, water presure are OK model gsd220g03
Posted on Mar 08, 2007
My whirlpool quiet wash plus diswasher is not draining water. How do I fix it?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 14, 2011 | Dishwashers
My diswasher has alot of water in it after we run the dishers thru. May be a clog? How can i check if there is a clog?
Hi
Daniel
Jun 19, 2011 | Hotpoint Dishwashers
The water will not drain out of the diswasher.
Hi
Daniel
Jun 16, 2011 | Dishwashers
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
My diswasher will not drain, it seems to have completed the cycle but the basin is full of water when it finishes.
Hi
Daniel
Mar 25, 2011 | GE 24 in. GSD6200G Built-in Dishwasher
My dishwasher is not draining all the way where is the drain? Maybe it is plugged?
Hi
Oct 25, 2010 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher is not draining after it is done.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Aug 28, 2010 | GE GSD4500G Built-in Dishwasher
Won't drain
Hi
Daniel
Aug 07, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Triton 24
Hi
Daniel
Jul 23, 2010 | GE Dishwashers
My diswasher does not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 08, 2010 | Whirlpool DU960PW Dishwasher
GE 24 in. GSD4020Z Built-in Dishwasher Logo
2,385 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
