Question about Nvidia GeForce FX 5500 Video Card Graphic Card
Hardware is not detected by the Computer
A rediculus problem is in my grafix card. After installing the hardware, when I started window then a "new hardware found" window appears. But when I click next to install the driver from CD along with garfix card it is showing that no suitable drier found. But for the first time it was working fine. And after that it is not working(After first installation, for 5 days I didn't got any problem but suddenly I got my screen lost it's resolution). Plz let me know how to fix this kinda problem.
  • 6 more comments
  • Anirban Paul
    Anirban Paul Dec 11, 2008
    I alredy have done this. It saying that hardware is not compitable with software, like this. But I'm doing this by the software comes in CD along with the Hardware.
  • Anirban Paul
    Sorry, yaar. I actually scrwed up. Actually I've done that 3dys before. But u plz give me a better solution. I conface what I've done. Plz forgive me. Plz get me out of this problem
  • Anirban Paul
    Plz help me out.
  • Anirban Paul
    Ok. After downloading I'll send u the result.
  • Anirban Paul
    No, driver is not working, it shows the "The NVDIA setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit".
  • Anirban Paul
    plz give me something to fix this problem........
  • den2x Apr 07, 2009
    I cn't install the Nvidia driver, it says " the nvidia setup program could not locate any drivers that are compatible with your current hardware." I've uninstall the onboard driver but still the same problem. My motherboard is Asus P5PE-VM.
  • Anonymous May 23, 2009
    President:
  • 2,110 Answers
Go to device manager and right click on graphics card..and select update driver..and give path as CD-Drive
Posted on Dec 11, 2008
Just bought new computer with Windows 7 Professional, put in my Soundblaster Audigy 2 sound card, disabled the Realtec card that came with the system, but the computer still doesn't acknowledge that new...
Disable the realtek from bios, then uninstall its drivers.
Reboot
If Soundblaster is not auto detected go to Device Manager and click on menu "Search for new hardware". After your card is detected, install specific drivers
Reboot
and that should do the trick.
Nov 02, 2010 | Computers & Internet
Audio devies not insttal
go to control panel add new hard ware and install it...
Sep 21, 2010 | Computers & Internet
I have a biostar p4m90-m7a mobo i installed 4gbs of ram & the only usable ram is 2.5gbs why?
i think u r using windows 32bit version thek can support only 4GB of memory,And memory includer grafix card ,ram motherboart etc so other 1.5GB is used by other hardware in your pc
Jan 29, 2010 | Biostar Computers & Internet
"no audio device installed"
First check the device manager from the control panel. Check and see if there is a audio device detected and if it is a problem device.If the device has a problem try removing the audio software and then remove the audio device.then re-boot the computer and windows should detect the hardware and begin installing drivers. Make sure you have the updated drivers from Dell downloaded and the updated software. If it does not detect the hardware after re-boot you can try adding hardware manually in the control panel and have it auto detect any new hardware. If these thins do not work the audio card or built in audio may have stopped working. You can buy a basic PCI audio car for fairly cheap to install on your computer if you cannot get the audio to work.
Sep 05, 2009 | Dell Computers & Internet
Colored lines on monitor
1)your grafix hardware is going bad(card OR onboard) -find a grafik card thats good with vista. 2)your monitor is bad,buy a new one,or try another one..
Dec 25, 2008 | Microsoft Windows Vista Home Premium with...
Driver is not installing
Check that the driver is compatible with your operating system
Vista or XP.
My card has 2 type of drivers
1 for XP and the other for Vista
You may be trying to install the wrong one
Dec 11, 2008 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
Grafix card
is it possible to start the computer in safe-mode ( press F8 on boot )
If the computer just crashes, it might suggest a hardware problem with the card in question. can you try it in another computer?
Mar 08, 2008 | Computers & Internet
My vga card is recognized but no working
if you have the disc with the drivers for your video card i would go to device manager click on the + sign next to display adapter ,right click on the video card and remove or uninstall it ,then reboot pc,when windows auto detects new hardware , sellect have disc, and insert driver disc,.....(if this is what you have done already with no luck ) then when windows detects new hardware ,close it and run the driver software from the disc,if you can't run the driver disc, windows will load the generic driver, . if you are not able to load windows normally, start windows in safe mode (press f8 when booting up and when you get a menue sellect safe mode) to remove display adapter, this has helped me in the past
good luck
Feb 20, 2008 | Computers & Internet
Motorola wireless adapter, Blue Screen Of Death
1. Uninstall the drivers for the card.
1.5 Turn pc off.
2. Unplug the card.
2.5 Turn on pc. Make sure the pc does not detect the wireless adaptor.
3. Turn pc off again.
3.5 install adapter then turn pc back on.
4. When windows tells you it has found new hardware, click the option to specify your own location for the dirver, then point to the cd that came with the card.
If all this still does not fix it, the you know its the adapter and to take it back.
This same solution works for any new card added to a computer. I have seen this same problem with the old scuzzy cards at work.
Jan 12, 2008 | Microsoft Windows XP Home Edition
Pci slot seems dead
so windows XP doesnt detect your new hardware. Try these suggestions:
1. Re install by reconnecting it to their respective slots.
2. Check, if the cards connected, supports PLUG and PLAY which means it can be detected automatically if connected to the slots.
3. If it is not plug and play, you have to configure it manually, try to install its software cd.
To see if it is already detected, go to the my computer and check the hardware devices connected menu (I hope you can browse to go to that menu) next, if it is already detected
all items listed there must have no question mark on it and X mark.
If you have this mark, it means that the driver is not installed yet or you have to reconfigure it.
Dec 16, 2007 | ASUS P4S333VM (AP4SRRVM) Motherboard
Nvidia GeForce FX 5500 Video Card Graphic Card Logo
341 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
